Go to Post I cannot inspire greatness with mediocrity! - Jim Zondag [more]
Unread 10-04-2009, 06:55 PM
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
pic: Simple single reduction duel CIM gearbox
Unread 10-04-2009, 06:56 PM
Re: pic: Simple single reduction duel CIM gearbox
What's the weight without the motors, but with the pocketed gears?
Unread 10-04-2009, 07:12 PM
Lowfategg's Avatar
AKA: Tyler Moser
Inventor is saying ~1.2 lbs, which seems to be a little bit of an over estimation (but with the long drive shaft it has now it might not be).
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 10-05-2009, 09:52 AM
Steve Kaneb's Avatar
Steve Kaneb Steve Kaneb is offline
I like two Championships, AMA!
AKA: Alex
FRC #0190 (Gompei and the H.E.R.D.)
Steve Kaneb is just really niceSteve Kaneb is just really niceSteve Kaneb is just really niceSteve Kaneb is just really nice
Send a message via AIM to Steve Kaneb
Why do you have the plates extending past the sides of the CIM casings? You would have to change the pocketing, but if you lop off those spare centimeters, you'll save some weight, space, and raw material.
In addition, you can probably get away with making 2 identical plates, even with the holes for the CIM screws. I would rotate the CIMs 90°, to make the symmetrical pocketing easier. Having swappable plates would aid greatly in manufacturing and would reduce the number of spares needed (not that these sorts of things break often).
WPI District 2016 Volunteer Coordinator.
2016 Referee: NE Granite State, NE UMASS Dartmouth, NE Rhode Island, NE Boston, NEDCMP
Unread 10-05-2009, 10:02 AM
EricH EricH is online now
It makes it easier to tighten the screws that hold the gearbox together. If you're going to do it this way, you have to be able to keep the plates together, and with the gear/motor setup, I don't think you can just assemble the box and put in the motor afterwards; you have to put the motor on the plate first. I'm not sure you can remove much sideplate length without reducing the ability to remove the screws in a hurry (say, in case of complete failure of a sideplate, requiring a complete teardown).
Unread 10-05-2009, 10:17 AM
NickE's Avatar
NickE NickE is offline
_
To save some weight, you could try having the CIM motor mount screws go through both plates with standoffs in between. This would eliminate the need for the four outer screws, and you could shorten the plates as Steve Kaneb suggested.
Might make the gearbox mounting difficult, though, depending on its mounting setup.
Unread 10-05-2009, 10:23 AM
artdutra04's Avatar
VEX Robotics Engineer
Complete failure of a side plate? I don't think I've ever seen that happen in FRC.
Also, those look like 1/4-20 screws to hold everything together. If the point of this design is to save weight, those are way overkill. Use tapped standoffs and #8 or #10 hardware, and you'll save a lot of weight. All #10/32 bolts are only approximately 58% of the weight of the same length 1/4-20 bolt.
Another possibility, depending on how the gearbox is mounted, is to use the #10/32 CIM mounting screws with four #10 clearance standoffs to hold the gearbox together. CIMs are pretty reliable motors, and generally don't ever need to be replaced if you do your homework. I wouldn't suggest this strategy for Fisher Price, Globe, or Banebot motors as they are more prone to smoke, but CIMs will take a lot before they give up the ghost.
As Steve pointed out, there's no reason to have both plates so big, unless they are specifically designed to mount in a certain way. The smaller and more compact something is, in general the less it weighs, due to the need for less material.
Art Dutra IV
世上无难事,只怕有心人.
Unread 10-05-2009, 11:28 AM
Using the CIM mount holes as the holes that hold the whole gearbox together is bugging me for some reason. It seems like things could get very complicated when it comes time to put the gearbox on the drive train, or arm, or wherever else it needs to be mounted. For a generic offseason gearbox, I think that what Tyler has is a great start.
I second the recommendation for making the sideplates identical. Doing so allows for additional flexibility during manufacturing should something go wrong.
GitHub
Unread 10-05-2009, 11:48 AM
DonRotolo's Avatar
Back to humble
FRC #0832
Nice job.
The pockets in the side plates do make it lighter, but they also hurt stiffness. The only thing holding the plates together are the four screws, right? And these screws connect to the center of the plate through a tiny strip of metal in each corner...
Allow for more metal between the screws and the center of the plate.
Unread 10-05-2009, 11:57 AM
Data Nerd
FRC #0079
Since the discussion seems to be focused on weight savings, one thing I havent heard mentioned yet is to drop from 3/16 to 1/8, will eliminate a 1/3 of the weight from the aluminum. Pocketing is great but it really doesnt remove THAT much weight compared to using thinner material. Either way you are using the same amount of material but often by using the thinner material you can eliminate machining operations. For example, I would be willing to bet that by using 1/8" you could not do ANY of those holes in the plates and the weight would be pretty close. On the other hand, it is better to have too much material where you don't need it than to not have enough where you do.
Also, why does that shaft have to be so long? That is probably a good deal of your weight, 1/2" steel, about 4" long? That is about .88 lbs right there.
Unread 10-05-2009, 01:46 PM
Lowfategg's Avatar
AKA: Tyler Moser
Thanks for the comments guys, I probably make a few changes based on some of the recommendations.
Swap the 1/4-20 bolts for 10-24, change the front plate to 1/8" (the rear plate needs to say the same because of bearing mounting), and maybe rework the pocketing and plate sizes a little.
I probably wont use the CIM mounting holes to hold the plates together and the shaft would be cut down to whatever size you needed once you knew the application.
Unread 10-05-2009, 10:47 PM
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Yay for simplicity!
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
pic: VEX High Reduction Gearbox JVN Extra Discussion 40 07-06-2009 04:58 PM
pic: 1712 version of JVN high reduction gearbox Rich Kressly Extra Discussion 11 04-29-2009 04:22 PM
pic: 1712 version of JVN high reduction gearbox - 2 Rich Kressly Extra Discussion 9 04-24-2009 01:14 AM
Gearbox/reduction for CIM,RS550,RS540 uid60001 Technical Discussion 8 04-03-2009 10:01 PM
CIM Reduction? excel2474 Technical Discussion 8 03-22-2009 11:08 PM
