Go to Post You can build bridges, or you can burn them. The choice is yours. - dlavery [more]
Unread 10-10-2009, 21:39
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
Re: pic: 6 Wheel Drivetrain
Originally Posted by M. Mellott View Post
You plan on using 25-series chain to drive the omnis...how will you tension the chains?
If you layout your sprockets and chain flat on a table you can get the dimensions center to center of the axels and you will not need tensioners. We did this on our test bot and it worked pritty good.
how does one go about making a 6 wheel config drivetrain? CuriousGeorge Technical Discussion 41 28-03-2008 20:57
pic: 1683 8 wheel drivetrain completed sdcantrell56 Extra Discussion 12 19-04-2007 02:20
pic: 1683 8 wheel drivetrain updated sdcantrell56 Extra Discussion 10 16-04-2007 18:08
pic: drivetrain CD47-Bot Robot Showcase 3 07-03-2004 20:35
