Go to Post I don't mind being odd...I like to - listen - to Dean Kamen's speeches. They make sense. I don't get to listen to a lot of sense in the world, just a lot of noise. - JaneYoung [more]
Unread 10-10-2009, 21:43
ajlapp ajlapp is offline
AKA: Anthony Lapp
pic: Wild Swerve Demo Chassis
Unread 10-10-2009, 21:44
Jared Russell's Avatar
Taking a year (mostly) off
Re: pic: Wild Swerve Demo Chassis
How much does this weigh?
Unread 10-10-2009, 22:32
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
So each module is driven by a window motor for turning? Since we only get two of the Denso motors in the kit (in past years), what motor is turning the other two modules? From the picture it looks like you are using four window motors.
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 10-10-2009, 22:58
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
This is just a demo bot, I doubt they were concerned about that.
Unread 11-10-2009, 00:33
Dr Theta's Avatar
Dr Theta Dr Theta is offline
AKA: Derek Messer
FRC #2232 (Deus Ex Machina)
Dr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud of
Looks like a beautiful swerve system. Kind of random question, where did you get the material that you used for the frame? I want to advocate using this sort of frame construction with our team this year.
Unread 11-10-2009, 01:11
EricH EricH is offline
Looks like 80/20 extrusion. There are many places to get it. The advantages are ease of modification and use. The disadvantages may include (note: may) having to readjust where that front frame rail [or other frame piece] is after every match due to fasteners. There are ways to get around that one, though.
Unread 11-10-2009, 08:28
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
To reiterate what Eric H said - 80x20 is problematic at times because the fastening system that it uses is simply not meant to withstand repeated bot collisions, etc.
My team used 80x20 for their bot their rookie year in '06. They resorted to using a sledgehammer between matches to force the bot back into shape by championships (and had to retighten every fastener between each match).
Unread 11-10-2009, 09:41
341 usually gets around this by using T-bolt fasteners for prototyping, but once the final design has been locked down we drill through the extrusion to make solid connections that don't budge.
The only other drawback of 80/20 (and Bosch extrusion, which is what we use) is that its strength to weight ratio is about 20% worse than for 1" square (.125" wall) tubing. For our team we are willing to eat this extra weight for the flexibility (and ability to avoid welding) that extrusion gives us.
Unread 11-10-2009, 17:20
AKA: Anthony Lapp
It came in around 100 lbs. The 80/20 extrusion is quite heavy.
This is not a FIRST robot. It was built to a customer specification. As a result they chose to use four AM Equipment motors. They are very similar to the kit motors.
AM Euipment Window Motor
That said, the steering modules pictured are designed to interface with either kit window motor or a globe motor. These will most likely be a part of our FIRST product lineup for 2010.
Anthony Lapp
FIRST Engineering Mentor
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Unread 11-10-2009, 22:22
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Besides that, trust me, it is a major pain to write SW to control 4 individually steered modules.
I suggest anyone doing crab/swerve should steer at least two wheels together with each globe motor. Either the fronts and backs together, or the sides together, depending on what type of flexibility you need for your driving strategy. For example, in 2008, having the two fronts tied together and the two backs tied together allowed what we call monster truck steering easily around the tight hairpin turns.
Last year, 2009, we tied all 4 together for the first time since the low traction surface made it moot to control them separately.
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 11-10-2009, 23:02
AKA: Anthony Lapp
This particular customer was interested in designing a platform that would tax their product and put heavy demand on their technology.
They eventually plan to put a different motor at each wheel to further increase the challenge.
Its been done before, Chief with tank tread swerve, independent steering at each wheel and a different steering motor at each location. One of them may have been a seat motor. If memory serve me. Circa 2001.
Anthony Lapp
RobotOpen
Unread 11-10-2009, 23:06
469 also had an 8 motor (non-coaxial?) swerve this year. They certainly had manuverability to play efficient defense, though I don't know how much of that was due to independent swerve steering; 111 was in my mind just as mobile.
Unread 17-10-2009, 08:09
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
Actually, this was the first year we didn't have 8 motor swerve and did 4 motor coaxial. We had 8 motor swerve the last two years (2007, 2008)...
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
Cyber Blue and Team 221 LLC "Wild Swerve" Chris Fultz General Forum 27 08-02-2010 14:47
pic: Team 221 LLC. - Wild Swerve Module ajlapp Extra Discussion 77 06-11-2009 17:33
pic: Wild Swerve Module, Near Production ajlapp Extra Discussion 20 03-08-2009 23:45
pic: Team 11 Gone Wild aallen88 Extra Discussion 4 01-05-2006 18:53
pic: Two wild and crazy Purple guys in NJIT Rich Wong Extra Discussion 3 09-01-2005 08:28
