Re: pic: Prototype FLL Table
But still a very cool idea! |
I'm thinking that tech specs can be found in the first thread: http://www.chiefdelphi.com/media/photos/34265?
FLL mats have always been too small for the tables... In this case, it's an optical illusion due to a lack of black paint. The right side wall has a lot of reflection. |
Gorgeous looking table, I hope we get to see an entire set of these because that will be impressive.
Also, is there any reason why they do that? Anywho. Gorgeous board, hopefully the insides can be done black at least. |
Ease of removal, I think. The problem is that you have to line it up right for teams because there will always be some team that is using distance from the wall on a fairly precise movement, and if your field is set up wrong (i.e., the black border line being under the wall instead of next to it), it'll throw them off and they complain.
Psst... My point on the mats still stands... Volcanic Panic and before didn't use mats... |
I guess that removal makes sense, easier way might be to just have a corner that you cut to make it easier to remove. Lining up is a HUGE issue for teams and field setup issues shouldn't be a factor. |
| pic: Why I work the FLL table | NorviewsVeteran | Extra Discussion | 13 | 25-03-2009 17:37 |
| pic: welding table | Bruceb | Extra Discussion | 8 | 23-03-2009 17:49 |
| Team 241's Turret Prototype ontop of the Harvester Prototype | Dantvman27 | Robot Showcase | 39 | 08-02-2009 22:53 |
| pic: 964's programming table | synth3tk | Extra Discussion | 18 | 14-12-2007 08:39 |
| pic: AZ Table Game | CD47-Bot | Extra Discussion | 13 | 15-03-2007 07:34 |
