Go to Post The difference between a robotics kid and a generic nerd. Both use their calculators for statistical analysis. One keeps it a closely guarded secret, the other brags about it on Chief Delphi! - Kevin Leonard [more]
Unread 10-27-2009, 03:44 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: pic: 2826 Halonomic Drive Prototype
Mecanums work in either the X configuration or the O configuration....Their current configuration is an X pattern on the ground. This provides slightly easier turning. An O pattern would be just as valid, but is slightly (just slightly) worse at turning due to roller angles.
A true X configuration would have the wheels in a perfect square with the mecanum rollers all pointing to the same point in the center of the robot. Such a configuration cannot reliably turn in place under its own power, and cannot prevent itself from being spun due to external forces. With the wheels in a longer (or wider) rectangle, this problem is less pronounced, but it still exists.
An O configuration is noticeably superior in turning performance, with both forward and sideways performance remaining the same.
pic: 1714 Polycarb prototype Crab Drive (backdrop1) xanarchyx Extra Discussion 38 11-01-2009 03:09 PM
pic: 1010 Drive system prototype joeweber Extra Discussion 10 08-24-2009 03:28 PM
pic: 1885's Drive Train Prototype JesseK Extra Discussion 5 02-01-2009 02:11 AM
pic: Crab Drive Prototype Weekend Build Alex698 Extra Discussion 9 01-13-2009 08:42 PM
pic: 213 - Drive prototype teaser Tyler M. Robot Showcase 10 01-07-2007 08:56 PM
