Go to Post I saw a big opening in the bees section and asked if we could sit for this match and was told we were welcome to sit there. Your team made space for about 15 of my team members that came with me. - Debbie [more]
Unread 10-27-2009, 05:43 PM
Jared Russell's Avatar
Taking a year (mostly) off
Re: pic: 2826 Halonomic Drive Prototype
Clockwise, O contact pattern on the ground, lines are vectors in a clockwise turn, arrows are vertical component of the vector:
\../ (^v)
/..\ (^v)
Clockwise, X contact pattern on the ground, lines are vectors in a clockwise turn, arrows are vertical component of the vector:
/..\ (^v)
\../ (^v)
Eric,
The problem is not with the vertical components of the vectors but rather with the horizontal. Also, I think that what I call "X" and what you call "X" are different.
So, using your notation:
Orientation of torque vectors - Vertical components - Horizontal Components
What I called "O":
/..\ (^v)(>>)
\../ (^v)(<<)
No problem here. The vertical components want the robot to turn CW, and so do the horizontal.
What I called "X":
\../ (^v) (<<)
/..\ (^v) (>>)
Problem! The vertical components want to turn CW, while the horizontal components want to turn CCW. The two cancel each other out as long as the roller friction is negligible.
Unread 10-27-2009, 05:51 PM
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
That looks sweet! The wheels look nice, did you make them your self? From our experience with an omni drive, the building was the easy part, and the programming is the hard part. Ours was drivable, but difficult to control. Hope yours turns out better than ours.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 10-28-2009, 05:06 PM
Tyler Olds Tyler Olds is offline
FUN Show Host
no team (First Updates Now)
Tyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond repute
Thank you for all the nice compliments, I will try to answer what I can, but this is a prototype and we have not gotten to test it on anything but a concrete floor. We are still making adjustments to the drive since we determined that we need to have an additional gear reduction so the motors do not kick out.
Originally Posted by Greg Needel View Post
I like the concept alot, I sketched something similar for a project I had an idea for. Can you tell me how this works on grass? Also can you control the height of the main body by adjusting your struts on the fly or is it just a fixed suspension driven by a shock?
We have not tested it off road yet, but the hopes of the suspension that we have is to take it in different terrains. It is a fixed suspension, however we have holes drilled to adjust each leg.
WOW that thing looks beastly! Are those 14 inch wheels? Got any video? That seems like it wond be really cool to see run and swerve. How much movement do the shocks have? Could they go, say, upside down? There's some small paralells to be drawn here; 1714 did holonomic in 2008 build, 2826 did crab in 2009, now those are reversed in the offseason... I guess I just find it funny.
It is a beast both in size and weight. I do not know the exact diameter of the wheels off hand. The shocks have a fully range of movement to the point that the frame will bottom out before the shocks give. The robot is not designed to drive upside down if it flipped over but it would be cool.
Originally Posted by big1boom View Post
Nice mechanum drive. Looks awesome, with some pretty cool machining.
Are those custom made wheels?
They are custom made out of polyurethane that we made in a custom mold.
Originally Posted by Andy Baker View Post
This is very, very cool. As with everyone else, I have a few questions:
What is the purpose of the scissor-like suspension? Is it to provide active suspension for the wheels, or does your wheelbase footprint need to change during your application?
What is the diameter of those wheels?
This is a very inspirational mechanism. I would love to see what all is going on within each of those suspension members.
Sincerely,
Andy Baker
Thanks Andy! The footprint does not need to change during usage, just to provide an active suspension. I should be able to post a couple pictures or video next week.
First Updates Now Show Host.
Watch and Listen to FUN on Youtube, iTunes, and www.firstupdatesnow.com
FRC Emcee 2009-2016: Team 2826 Wave Robotics Lead Mentor 2001-2004 Team 93 NEW Apple Corps Alumni
CD Moderator
Unread 12-10-2009, 10:38 PM
FUN Show Host
Got a short video uploaded on youtube. I took this at midnight on the spur of the moment so this is nothing professional. Look for a longer video in a couple weeks. There are still many more tweeks that will be done, hopefully sooner than later.
*Oh and the 2x4 was just randomly laying there*
http://www.youtube.com/watch?v=WmvuXQUobQM
CD Moderator
Unread 10-27-2009, 07:16 PM
EricH EricH is offline
Originally Posted by Jared341 View Post
Eric,
What I called "O":
/..\ (^v)(>>)
\../ (^v)(<<)
What I called "X":
\../ (^v) (<<)
/..\ (^v) (>>)
I see now.
I also think that X and O should be "standardized" at a certain view for future reference. I'll let wiser heads than mine figure out whether you do it from the top or bottom, though.
Unread 10-28-2009, 12:10 AM
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Can this robot flip over and still drive? That would be awesome!!
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
pic: 1714 Polycarb prototype Crab Drive (backdrop1) xanarchyx Extra Discussion 38 11-01-2009 03:09 PM
pic: 1010 Drive system prototype joeweber Extra Discussion 10 08-24-2009 03:28 PM
pic: 1885's Drive Train Prototype JesseK Extra Discussion 5 02-01-2009 02:11 AM
pic: Crab Drive Prototype Weekend Build Alex698 Extra Discussion 9 01-13-2009 08:42 PM
pic: 213 - Drive prototype teaser Tyler M. Robot Showcase 10 01-07-2007 08:56 PM
