Go to Post I'd say go out and kick their collective boo-tays...in a non-damaging, graciously professional manner, of course. (wink wink) - Billfred [more]
Unread 28-10-2009, 17:41
Data Nerd
FRC #0079
Re: pic: 1714 Polycarb prototype Crab Drive (backdrop1)
While I agree with you for many potential components (I'd think making an AL swerve module would probably be a much safer option), a lot of times for our team there would be little benefit to building the robot out of aluminum when our resources for building that component out of polycarbonate are significantly greater. Take this year's robot, not a single structural failure, and we fabricated the robot faster this way than we would have if we used aluminum. In some cases it's better for our team to use polycarbonate only then. The tricky part is when we come across a game that basically requires a very strong, light part that isn't protected by foam bumpers...
I agree entirely, if you have better resources for working with a material and a part can be made out of that material without impacting its performance then by all means make it out of that material. I was merely remarking on a general concept that I see too often, people assume that one material is "better" than another. For example, a lot of times people will assume metal > wood. This is wrong, metal > wood in some applications in others the converse is true. In engineering, as in life, everything is a tradeoff. For example this component, while making it out of Aluminum may be safer and lighter (may or may not be the case but this is just an example so it doesn't really matter) you can fabricate the Polycarb easier. Which one you decide is based on certain criteria. As I said, just a general statement geared more towards a general audience than your specific design.
I do like the fact that you guys are finding limits of polycarb with PolyCrab. I just would like to see how it holds up compared to Aluminum. Perhaps do some tests (either in CAD or on the actual thing) to see how it holds up. This is the off season, why not take the time to find where you can cut weight out or where you need more material?
pic: Crab Drive Prototype Weekend Build Alex698 Extra Discussion 9 13-01-2009 20:42
pic: 1771 crab drive sdcantrell56 Extra Discussion 9 29-06-2008 00:02
pic: A closup view of our prototype worm-crab drive system. AndyB Extra Discussion 6 20-01-2008 00:02
pic: Coaxial Crab drive CraigHickman Technical Discussion 1 21-06-2006 16:03
pic: Crab Drive Joe_Widen Extra Discussion 3 23-04-2006 15:49
