Thread Tools |
Rating:
Display Modes |
Re: Daves Game Hint
So, FIRST is turning into the For the Inspiration of Science and Trains? That makes sense... Not a whole lot of re-branding will be needed....
Re: Daves Game Hint
According to Wikipedia:
"In England some early lines in colliery (coal mining) areas in the northeast of the country were built to a gauge of 4 ft 8 in (1,422 mm)... George Stephenson used the 4 ft 8 1⁄2 in (1,435 mm) gauge (with an extra half-inch of free movement to reduce binding on curves) for the Liverpool and Manchester Railway, authorized in 1826 and opened 30 September 1830. The success of this project led to George Stephenson and his son Robert being employed to engineer several other larger railway projects... The influence of the Stephensons appears to be the main reason that the 4 ft 8 1⁄2 in (1,435 mm) gauge became the standard, and its usage became more widespread than any other gauge." Thank you, Wikipedia, and Norviews for the context ![]() |
Re: Daves Game Hint
Alright where to trains leave us where...:
The game is based on tracks; -Robots move on tracks. -Certain robots move on tracks. -Move on Tracks for Bonus points. The game involves train like movement; -Alliance moves like a train. -We pull trailers (again). -Alliance moves like a train for a special period (start/end game). The game involves train-like properties; -Alliances must use combined force to move game pieces. -Alliances must pull/push game pieces Train Construction: - Alliances need to haul objects, place objects, and hammer objects to score. - Alliances need to build something out of game pieces. What else you got? |
Re: Daves Game Hint
Being here for a while, 6,462 mi doesn't seem like much. It's only a distance between these two places.
Re: Daves Game Hint
What about 2008's game pieces, the track balls?
Could we see a new use for the old game piece? |
Re: Daves Game Hint
I thought those things were awesome.
Re: Daves Game Hint
After reading Bill's Blog today and in his past posts he talks about the current field being developed as the "Delta" field this could simply be the forth iteration of the FIRST field with cost savings features added for the expanded number of fields OR it could also mean that the field/field elements will change from match to match or even during the match.
Another possible hint came when he talked about the use of the classmate PC this year as the driver's station, in the blog he said they played some matches, changing sides, and changing alliances with out problems this could mean that alliances will be changing throughout the course of the match. the Dartfish software that is being tested for this year is used to overlay video replays of multiple actions, it's been used with '06 robots shotting at the goal and I have also seen it used in air racing to compare the path each plane took around the course. This also hints at the changing field, the Dartfish replay would allow everyone to see the robots doing their tasks as the field changes. Danny B "67 days until kickoff " Bills Blog Last edited by Danny Blau : 03-11-2009 at 15:52. |
Re: Daves Game Hint
Re: Daves Game Hint
Danny, I'm pretty sure he's simply referring to the testing; during a competition, each individual control system has to be able to connect to the field from any one of the control stations, no matter what is in the other X stations on the field, and then disconnect and reconnect in any station again, in whatever pattern the field is looking for. I don't think we'll see changing alliances during a match; imagine what that would do to eliminations... |
#10
Re: Daves Game Hint
With all the train references, perhaps we'll need to get some TRAINING this year...
#11
Re: Daves Game Hint
The reason I bring up changing alliances is because it was talked about when designing a VEX game for a local competition and one idea was that if you controlled a certain game piece you could high jack a robot from the other alliance. However without having the VEX bots tied into a field control this would have been impossible to control and difficult to follow for the fans. With FRC though the alliance could be changed, the field used to controls your red/blue LED lights anyways and for eliminations; its all based on what teams are on alliance with the most points at the end of the match and thats the way you start the next match. If your alliance thinks they can win alone this give motivation to prevent a switch and if you think your done for your going to try and switch. the strategy would be all messed up think if red spent the whole match scoring on themselves and then at the end switched sides to steal the win. FIRST is always looking for ways to make things harder and more interesting and this would sure do it. but hay I could be completely wrong Danny B |
#12
Re: Daves Game Hint
In addition to totally confusing the teams, not to mention the Joe-off-the-street types we want to see us and the VIPs, you have to figure out how to assess the penalties that happen (which alliance gets the disable/DQ when teams are switching) and all the rest of that stuff. It's not impossible. It's just crazy to do. Technically possible? Sure, if you can tell the robots that they just switched (and the drivers, for that matter). But it's your worst nightmare in terms of tournament play and who advances. Now if the entire alliance simply switches colors, that's another thing (and almost pointless). |
#13
Re: Daves Game Hint
All I'm saying is that it would be possible, it would really shake things up and its not like FIRST hasn't gone with crazy in the past, I know the first time I hear that we would be playing on fake ice I thought it was crazy, six weeks is crazy, helping a team that's your opponent later is crazy but it happens all the time.
it would bring a new level of cooperation to the game and would really make things interesting. It has more chance than a water game but only slightly, anyways I'm still hoping for it (well both actually) Danny B keeping the water game hopes alive |
#14
Re: Daves Game Hint
Re: Daves Game Hint
What I was referring to was if a team wanted to make a video using the video that was shot from the regional authority, would they be able to use it?
| Game Hint #1 | Ice Berg | Rumor Mill | 898 | 03-12-2009 20:35 |
| Game Hint #2 | Zflash | Rumor Mill | 539 | 07-01-2009 16:14 |
| Game Hint #3 | SuperJake | General Forum | 1 | 29-12-2008 14:59 |
| Game hint?!?! | Andy Grady | Rumor Mill | 67 | 30-12-2002 18:15 |
