Go to Post We want to be a positive force in our community, and maybe to encourage our country’s best and brightest to go to work for the ones who’ve put themselves in harm’s way. - Jack Jones [more]
Unread 04-11-2009, 01:59
Fe_Will's Avatar
Fe_Will Fe_Will is offline
AKA: Will
FRC #0955 (CV Robotics)
Fe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud of
Talking Re: pic: 955 T-Shirt Bot @ Halftime
Thanks for the comments and I'll try to respond to all of them.
First of all, I should give credit to team 1716 and this for inspiration.
We are using 2 tanks for two reasons:
  1. Alternating between tanks allows us a faster firing rate.
  2. Firing both tanks at the same time allows us to fire long shots.
The system is all 2" schedule 40 galvanized steel pipe except for the brass ball valves and the ABS barrel. The 2" ball valves are opened by 1.5" diameter 8" stroke pistons. We could not locate 3" galvanized for the barrel locally and buying it on line was too expensive.
Yes we have a leak somewhere in the system. Also, four of the five compressors filling a tank took 15 seconds to reach 120 psi. We had some serious run time regardless of the leak during the game.
We are scheduled to be at this Friday's game as well and we are taking measures to improve our performance. We haven't done much driving on the track except straight forward and reverse, it accelerates pretty well (~20ft.).
Our best shot was firing both tanks at the same time, one was at 120 psi the other was at 135 psi. I'd say it was about 90 yards with the barrel at a max elevation of 40 degrees. (For those of you wondering, the galvanized is rated for 180 psi and we have pop-safety valves on each tank that vent at 150 psi.)
"It is the mark of an educated mind to be able to entertain a thought without accepting it." -Aristotle
FIRSTcast: Season 4 Episode 7 - Halftime Jeff Rodriguez General Forum 0 27-01-2009 12:55
pic: Nah, We just have a set for the Alpha bot and the beta Bot Kevin Ray Extra Discussion 10 25-01-2009 18:40
Team 955 Karma Website Design/Showcase 7 25-02-2005 01:22
Team 955 Animation Storyboard Li Jianliang 3D Animation and Competition 0 13-02-2005 16:01
Congrats to 254, 1425, 753, and 955 Nate Edwards Thanks and/or Congrats 2 21-03-2004 18:13
