Go to Post If you refuse to come to any compromises with your Ultimate Ascent robot design, you risk compromising everything (including your sanity). - Jared Russell [more]
Unread 02-12-2009, 22:32
Gdeaver Gdeaver is offline
FRC #1640
Re: pic: 3/4" Plywood Frame
Plywood is mother nature's composite. If you add in some epoxy and glass, Kevlar or carbon fiber cloth, you can make a very light and durable wood structure. Our team this year is contemplating making our bottom electronics board out of 5mm birch plywood laminated on both sides. The panel in our design is also a structural part of the frame. To keep the weight down requires vacuum bagging. We could buy other material for this part or buy pre made panels. I'm going to work with the students laminating the panel to give them some exposure to composite construction. There are many good tutorials on the web showing how to do this. However it does take some practice. It wood be a good off season project. You don't want to decide to do this during build season with out some practice. Allot of FRC teams are addicted to metal. They should get some fiber in their robot diet.
Bumper Plywood Backing Skifanatic Technical Discussion 3 10-02-2009 18:20
pic: plywood+mill = wooden omniwheels?!? Stuart Extra Discussion 4 06-02-2007 14:35
grip on dusty plywood greencactus3 Technical Discussion 5 12-01-2005 18:41
Wheels - Plywood Denman Technical Discussion 10 04-02-2004 08:38
Question about Plywood thickness KennethToronto Technical Discussion 4 06-02-2002 15:20
