Go to Post I wonder if it could be... Nah, that would just be way too... Never mind. . - dlavery [more]
Unread 04-12-2009, 15:15
flyguy93's Avatar
flyguy93 flyguy93 is offline
AKA: Alex
FRC #2420 (Robo TItans)
Team Role: Electrical
flyguy93 is an unknown quantity at this point
pic: David on the drill press
Unread 04-12-2009, 15:16
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: pic: David on the drill press
What is wrong with this picture?
Unread 04-12-2009, 15:18
Rich Kressly's Avatar
Rich Kressly Rich Kressly is offline
Robot/STEM troublemaker since 2001
no team (Formerly 103 & 1712. Now run U.P. Robotics (other programs))
Rich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond repute
Clamps?! Unless there's a tightened fastener holding the part in place I can't see...
technology, innovation, and invention without a social conscience will only allow us to destroy ourselves in more creative ways
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
I count three things.
Hi!
Unread 04-12-2009, 15:19
MrForbes MrForbes is offline
Something about the clamping system makes me cringe....
Unread 04-12-2009, 15:30
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Dangly jewelry.... could pose a choking hazard... and is a serious fashion faux pas
Unread 04-12-2009, 15:31
I'll amend my post slightly and say IF the drill press is on and IF he's actively drilling a hole, then there are safety issues. I will admit it's a little hard to tell from the photo and it's possible the student is just lining up the part for placement without the press being on. In which case I'm hopeful the clamp(s) would be the next step :-)
Unread 04-12-2009, 15:32
EricH EricH is offline
1) Lack of clamping, unless there's something I can't see.
2) Can't tell if the necklace is in fact tucked in. If it is not, that's a hazard.
3) Something goes wrong, and the press retracts, his head's going to get hit by the lowering handle.
4) Can't tell for sure, but it looks like he may be using a drill press and drill bit as a mill and mill bit. You *might* get away with the first one, if you use a mill instead of a drill bit. You don't want to do both, though.
He is in fact wearing safety glasses, which is a good thing. However, they can't protect you completely.
Unread 04-12-2009, 15:37
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
As a Occupational Medicine physician, I have soon numerous injuries involving foreign objects in the eye even with the use of safety glasses, or welding shields. The problem is that metal or wood fragments land on the safety glasses' frame and when removing the glasses, the fragments fall into the eye.
One solution is a piece of double-sided tape on the top edge of the frames if you are grinding or sanding.
Lets make the 2010 season accident-free!
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 04-12-2009, 15:56
ATannahill ATannahill is offline
AKA: Alex Tannahill
ATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond repute
Gloves?
- Arizona North
Unread 04-12-2009, 16:02
Originally Posted by rtfgnow View Post
Gloves?
Incorrect. Gloves are in fact a safety hazard when used in that type of proximity to a rapidly rotating object, such as a drill or mill bit. Same reason as long hair and necklaces.
Unread 04-12-2009, 16:20
Joining the 900 Meme Team
FRC #0079
I've done both of these, the first one hurts. The second one I didn't realize until someone mentioned it (there is a reason I don't machine) I had mixed up a drill bit for a mill bit on the mill. Nothing broke thankfully but the teacher was pretty sure that was only because I was cautious and not forcing it to cut much of a soft material. (Ok, look, I COULDN'T force it, I weighed in at a whopping 80lbs and had to get a ladder to change the bit)
So, in my way too informed opinion, DON'T DO EITHER OF THESE!
Clamp that thing down, it may seem relatively harmless but anything spinning at >1000 rpm is dangerous add into that the likely hood that it will fall off and fling at you and you are in trouble.
pic: David Kelly after winning the 2009 Chesapeake WFA Pat Roche Extra Discussion 14 25-03-2009 02:02
Free Drill Press, Belt/Disc Sander, and Metal Bin Rack Cory General Forum 7 28-12-2008 20:27
pic: CD Makes the Oakland Press Beth Sweet Extra Discussion 1 04-03-2006 16:03
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
