Re: pic: Wheel Idea 2
Ok, Here are a list of things that I could improve upon that I have taken from everything that has been said.
1. Switch from hex to circles. (Would it be better to go for a keyway circle? Or keep the hex on the drive? ) 2.Trash the outside ring on the hub and make the spoke longer. 3. Take off the fillet on the hub. 4. Take off some of the width on the spokes. If I have left anything out or am misinterpreting things, please, do not hesitate to correct me. -Rion |
The choice of hex broaching for direct driving is based on our resources and experience with hex. |
Rion if you ever get some time. Send the wheel over to me and I'll take a look at it. I'll be able to give you detailed explanation of things.
-RC |
I know I'm learning from these posts, so I'm sure others are too. |
| pic: Wheel Idea 1 | Rion Atkinson | Extra Discussion | 12 | 14-12-2009 14:59 |
| Detecting wheel slippage! Possible idea, amp/power feedback in Jaguars. | 7-11number1 | FRC Control System | 1 | 10-01-2009 18:25 |
| pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! | jskene | Robot Showcase | 25 | 18-02-2005 20:24 |
| New Format - Good Idea/Bad Idea? | Harrison | Chairman's Award | 4 | 07-11-2002 16:28 |
