Go to Post Man I hate it when people muddy up our rampant speculation with facts and logic, jeez :D - rsisk [more]
Unread 15-12-2009, 07:57
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
Re: pic: Air Suspension
We are using this design to replace our curent design. The old design cuts off the front of the robot and would create design problems with game collection peices. The new design clears the front and also makes it stronger.
Below is the old design
Unread 15-12-2009, 08:40
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Joe,
I would just like to make you aware that in the past, using mechanical force to move a piston and create pressure was deemed illegal under the robot rules. Each year pneumatic rules change but before you dedicate your design, please wait for kickoff and then ask the question through the Q&A.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 15-12-2009, 09:56
EricVanWyk EricVanWyk is offline
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Regardless of legality, have a few students write white papers on these different approaches. Make them thoroughly research and explain them, and include pictures of the beasts. It will make applying to college and getting scholarships into a cakewalk.
Very cool designs!
Unread 15-12-2009, 10:18
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Originally Posted by Al Skierkiewicz View Post
Joe,
I would just like to make you aware that in the past, using mechanical force to move a piston and create pressure was deemed illegal under the robot rules...
I don't think the rules have ever been quite that specific and restrictive. In many applications, the robot mechanisms "push back" on the pneumatic cylinders and can potentially pressurize the system. In my experience, the main thing the inspectors have watched for in such cases is that a relieving regulator prevents overpressurizing things.
You wouldn't be permitted to use a totally closed pneumatic system as shown in the drawing. You'll want to put a regulator on it to maintain the desired pressure anyway, and that ought to take care of it.
Unread 15-12-2009, 10:26
GaryVoshol's Avatar
Cogito ergo arbitro
You have to watch what this does to your bumper zone, should bumpers be required again this year.
(since 2004)
Unread 15-12-2009, 15:52
dtengineering's Avatar
AKA: Jason Brett
Joe,
...using mechanical force to move a piston and create pressure was deemed illegal under the robot rules.
Al makes a good point... but it got me thinking that a system like this could be tied in to the robot's pneumatic system and you could actively raise or lower the pressure in the system to achieve different ground clearances... when you want to hold position and not be pushed around, just lower the robot frame right down on to the ground!
But regardless of FRC legality, this is a cool project on its own right.
Jason
Unread 15-12-2009, 16:18
NickE's Avatar
NickE NickE is offline
_
One thing I can think of to do this is have this pneumatic system on a secondary regulator and use a servo to actively change the pressure of the secondary regulator. I'm not sure if this is legal but it'd be interesting for sure. You could adjust how springy your suspension would be. Another idea would be to use a center-closing solenoid and close the solenoid when the piston is wherever you want it to be.
Unread 15-12-2009, 17:23
Creating pressure using mechanical force on legal pneumatic component has been deemed illegal in the past. Reasoning behind such a rule is the possibility of a pneumatic system already at full pressure, with flow restrictors, could conceivably exceed system pressure of 125 PSI if pushed on with enough force.
Also, until last year, pressure modulators were not allowed. Last year, a few changes in the rules did allow them and I remember seeing one robot that had somehow controlled a pressure regulator to achieve a desired effect. I don't remember if it proved advantageous or not.
Al
WB9UVJ
www.wildstang.org
Unread 15-12-2009, 17:57
Rion Atkinson's Avatar
The CAD Guy
I am loving the idea. It would prove very advantageous for anything. It has true real world potential. If legal it FIRST I would love to see it on a bot.
I agree with Gary, bumpers could cause a problem..
Unread 15-12-2009, 18:19
joeweber's Avatar
Coach team 1322
As shown on our other post http://www.chiefdelphi.com/media/photos/34389? we would attach the bumpers to each section of the drives which would allow them to move up and down with the wheels keeping them at the correct height. The only problem I see is the bumpers could be called articulating which would be illegal.
Far as the pneumatics I Like the idea of having a pressure relief valve and a pressure regulator to make it legal.
Unread 15-12-2009, 18:28
The CAD Guy
That makes perfect sense. A very good idea. And the argument of if the bumpers are articulating or not could be argued every which way.. Technically I would say they wouldn't be. What is the difference between a robot with center drop and this when it comes to the bumpers? They are moving up and down (Now yes not as much, but none the less. They are moving) so couldn't that technically be called articulating? The bumpers would only move with the wheels, which would go with the level of the ground, so wouldn't they technically never go above or below the rule book's allowance?
Just my thoughts. I may be misinterpreting something..
-Rion
Unread 16-12-2009, 08:05
Eric,
Pneumatic vacuum using cylinders was allowed in 2007 after some discussion, in 2004 it was not. The only legal vacuum devices prior to 2007 were venturis which create vacuum but not by mechanical force. However, even these were not legal in most years.
From 2004 Robot Pneumatic section rules <R54> revised...
• A device that creates a vacuum is not considered to be a pneumatic device, and is allowed. This includes, but is not limited to, venturi-type vacuum generators and off-the-shelf vacuum devices (as long a they are powered by one of the Kit motors).
Some teams used vacuum pumps that were COTS items, removed the motors and replaced them with KOP motors. The FP was the motor of choice that year.
Al
WB9UVJ
www.wildstang.org
Unread 16-12-2009, 12:40
EricH EricH is online now
Eric,
Then two teams were using illegal mechanisms in 2004; a pair of West Coast teams used a setup similar to 386's 2007 one to try to create suction on the 2X ball.
Unread 16-12-2009, 15:42
Eric,
That is a possibility particularly if this was a week one or two event. I did not look into which Q&A prompted which Team Update, I merely quoted the final robot rules revision.
I do remember at least one team, buying a cheap vacuum cleaner and replacing the motor with an FP. It worked fairly well as I remember.
Al
WB9UVJ
www.wildstang.org
Unread 16-12-2009, 18:12
Brandon Holley's Avatar
Not to mention Baxter's bot that year....that was a thing of beauty.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
pic: Robot suspension joeweber Extra Discussion 11 15-01-2010 20:32
pic: 8WD 'Suspension' Chassis Concept JesseK Extra Discussion 8 09-12-2008 22:00
pic: 6 wheel suspension joeweber Extra Discussion 16 13-11-2008 18:22
pic: FRC 1726 suspension MrForbes Extra Discussion 4 22-12-2006 15:57
pic: vex suspension psyco_klown Extra Discussion 9 14-11-2006 22:18
