Going to make some guesses, I assume this is drop center? How is the weight distribution front to back? Looks rather centered. I would suggest avoiding this, there have been many reports of the rock causing unpredictable behavior. Left to right distribution looks ok.
Why on earth did you stay 2d with the electronics? This many ESCs screams to move into 3d space. It will make packaging a collection mechanism (if applicable) much easier and make your electronics guys less likely to kill you. Where are the paths for the wires? You have to have a bundle of 14 10 gage wires from the back of the bot (PD board) to the front (Victors). Trust me, that won't be fun. Suggestions; Remove one of the 884s, space the rest out a bit. Turn the Jags 90 degrees either way, you have a cross bar right next to them which will make servicing them nasty. Also, make mounts for them to sit at a ~30 degree angle with a slight overlap. This will open up a path through the middle of the chassis for the wires to run to the front. Move your on/off switch closer to the back to let wires run where it is now. Running your PWM cables is going to be miserable, get some clearance between anywhere you need to place a cable and any frame members.
Can you tell that I am a wiring/programming guy?
Looks nice other than those minor complaints. Very clean render, thank you for not making it grey on a black background. Very crisp and clean, I can actually see everything.
As for lightening, I assume that is 1.5x1? Take a .75" bit and pop a hole every 1.5". Probably doesn't look as cool but it is a pretty simple process, you know, a job for a freshman (or a programmer).
<unrelated>w00t 1001st post</unrelated>
