Go to Post Honesty and integrity should always be taken seriously. It's the lubrication that makes the world go round. - rsisk [more]
Unread 19-12-2009, 16:25
NickE's Avatar
NickE NickE is offline
_
Re: pic: 1557 crab module
Originally Posted by gorrilla View Post
the way i was thinking about supporting the shaft is, get the optional long shaft(Hex because thats what we bought hubs for) and a hex bearing, then just bolt a piece of aluminum plate to our top plate, put the hex bearing in it, and then put the shaft through it with the screw and washer on the outside.
Sounds like it would work. You might consider removing one of the toughbox bearings if you do this. I've always been taught not to put more than 2 bearings on one shaft.
pic: 1557 crab module gorrilla Extra Discussion 4 23-12-2009 13:13
pic: Banebots- AndyMark crab module Greg Needel Extra Discussion 9 10-01-2007 21:24
Inexpensive crab module? Jeremiah Johnson Technical Discussion 20 24-04-2006 17:10
pic: Tytus's Coax Crab Module CD47-Bot Robot Showcase 8 17-11-2003 10:08
