#11
Re: pic: 1557 crab module
The pod does look heavy, but I really like the simplicity of it. It looks like it's only 4 or 5 parts with minimal machining involved, which is nice. If you wanted to keep the pre-made gearbox idea but save weight, I would recommend going with the Toughbox Nano
As far as the side loading goes, I would say for prototyping you're fine because the gearbox does dually support the shaft and the shaft isn't too long. However, I do like the idea of putting on the long shaft and moving one of the Toughbox bearings, if possible, just to be safe. |
| pic: 1557 crab module | gorrilla | Extra Discussion | 4 | 23-12-2009 13:13 |
| pic: Banebots- AndyMark crab module | Greg Needel | Extra Discussion | 9 | 10-01-2007 21:24 |
| Inexpensive crab module? | Jeremiah Johnson | Technical Discussion | 20 | 24-04-2006 17:10 |
| pic: Tytus's Coax Crab Module | CD47-Bot | Robot Showcase | 8 | 17-11-2003 10:08 |
| pic: 217 Gen 2 Crab Module Section view | CD47-Bot | Robot Showcase | 2 | 28-04-2003 18:26 |
