Go to Post The programmers will kill you if you want that done on the robot!!! - cbeavers6790 [more]
Unread 21-12-2009, 16:20
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: pic: Wheel 4 V1.2
Originally Posted by CraigHickman View Post
Cough
. It's possible to pull off some VERY light wheels while still maintaining plenty of strength. Those are 1/4" Thick spokes, two 1/4"x1/4" bar per spoke area. In the bottom wheel, the ends are radiused for extra strength (and style).
I believe it's side loads that Raul was worried about. Your extra strength radius doesn't seem to address that.
pic: Pic 2: "caster wheel" crab drive combo adengler Extra Discussion 7 27-01-2009 21:14
pic: Pic 1: "caster wheel" crab drive combo adengler Extra Discussion 1 25-01-2009 17:44
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 17-01-2007 01:21
pic: da wheel CD47-Bot Robot Showcase 11 08-02-2004 22:04
