Go to Post I'm looking forward to seeing it in action! That is one sweet looking gun. The look on his face has me a tad worried though.... - Zholl [more]
Unread 21-12-2009, 19:41
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: pic: 1557 crab module
Originally Posted by gorrilla View Post
why?
2 points define a line. In the same way, 2 bearings constrain a shaft. Adding a third point (bearing) over-constrains the line (shaft). It is inevitable that there will be some misalignment between these three bearings. If your tolerances are very good, and the misalignment is very small, the consequences are increased shaft stresses and friction. If your tolerances are not as good, the mechanism may bind and not function at all.
Another example of this problem is a wobbly pedestal style table or chair. 3 points define a plane. When you add a fourth point, such as a four legged table or chair, you are over-constraining the design. If the tolerances are good (and the surface the object is placed on is a smooth plane) the issue is unnoticeable. If the tolerances are not tight enough, or if the table is placed on a surface that is not a smooth plane, the table or chair will wobble between two different three-point planes. A rectangular table with legs on the corners is less likely to suffer from wobbling because a virtual degree of freedom is provided by the flexing of the table surface, allowing for four constraints to all be met.
pic: 1557 crab module gorrilla Extra Discussion 4 23-12-2009 13:13
pic: Banebots- AndyMark crab module Greg Needel Extra Discussion 9 10-01-2007 21:24
Inexpensive crab module? Jeremiah Johnson Technical Discussion 20 24-04-2006 17:10
pic: Tytus's Coax Crab Module CD47-Bot Robot Showcase 8 17-11-2003 10:08
