Go to Post It's far easier to find ambiguity in the rules than to write them. - MikeE [more]
Unread 20-12-2009, 16:04
Cjmovie's Avatar
Cjmovie Cjmovie is offline
1293 Resident Hacker
AKA: Christopher Corsi
FRC #1293 (D5 Robotics)
Cjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to all
pic: CNC Router Project
Unread 20-12-2009, 16:07
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
Re: pic: CNC Router Project
Nice. We have thought of doing exactly what you have done but have never got around to doing it. How are you comtrolling location? We were going to use a joystick on ours our use light sensors and a pattern.
Unread 20-12-2009, 16:42
Cjmovie's Avatar
We've actually dedicated an old Pentium-4 computer to its control. The parallel port runs to the stepper motor controller (a Gecko G540) to control all four stepper motors. There are two on the X (one on each side driving an acme leadscrew) and on both the Y and Z. Theoretical accuracy is actually limited by the precision of the leadscrew ("precision acme leadscrew", off of mcmaster) which put us at around 7 thousandths of an inch over a foot.
We're using EMC2 software to do actual movement control, which runs industry standard g-code. See here for a sample of what it actually cuts:
http://d5robotics.org/Content/View/942/No_Title
On top is the aluminum plate we had cut at our sponsor's place on a waterjet. On bottom is an engraving of the same plate into a piece of MDF. It's capable of cutting through but would have had to do multiple passes (we didn't set it up for that in this case, just testing accuracy). If you hold the aluminum plate on top of the MDF, they match up exactly.
D5 Robotics, Team 1293: Programmer, CAD'er, Mechanical, Electrical... I've made my rounds.
Events: 2006-2009 Palmetto Regional
Website: http://d5robotics.org/
Unread 20-12-2009, 17:26
Curious, what steppers are you using, and what voltage and current do they run at?
Unread 20-12-2009, 17:35
Cjmovie's Avatar
We're using 387 oz-in steppers running on 48V. They have 1/4" shafts with a flat so we just used lovejoys to connect them to the leadscrews. You can get these at KeilingCNC - http://www.kelinginc.net/index.html
Unread 21-12-2009, 20:54
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Molten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond repute
Ok, call me a fool...but can someone explain what's making the noise and how?
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 21-12-2009, 21:12
Rion Atkinson's Avatar
The CAD Guy
It's my understanding that it is the step (Do I have that name right? ) motors that cause the sound. It happens on all CNC machines.
‎‎"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. -Albert Einstein
Start Something
Email - rionatkinson@gmail.com
Skype - Rion.Atkinson
Unread 21-12-2009, 21:18
Molten's Avatar
AKA: Jason
But how do they make the noise? I want to understand the physics.
Unread 21-12-2009, 21:24
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
I'm not 100% sure, but this is what I think:
Are you familiar with how stepper motors work? When electricity is applied to them, they go one "step," so in order to get them to move a full rotation, electricity has to be turned on and off and back on multiple (or actually hundreds/thousands) times (depending how many "steps" per rotation the motor has).
To get the motor to go at different speeds, you turn the power on and off at different rates. Pulsing something at hundreds of times a second creates different notes. For example, when you hit a tuning fork for the note "A," it vibrates at 440 Hz.
Thus, moving a motor faster means faster pulses, resulting in a higher note. And slower gives you a lower note.
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 21-12-2009, 21:29
Cjmovie's Avatar
Using this as a reference point:
http://en.wikipedia.org/wiki/Stepper_motor
Basically, stepper motors differ from normal motors in that they move to certain, pre-defined rotations instead of just rotating at an RPM approximated by voltage. So you send a signal to a stepper motor, it moves one step (usually 1/200th of a revolution or so), and you send another and it moves another step, etc. (slightly more complicated, but the wikipedia article can tell you that).
Since it's not a constant motion (it's stop start stop start to at least a small degree, even when "smoothly" rotating) there's a vibration created. The frequency of this vibration is the rate at which you're sending pulses to it, since this is the speed that it's stop-starting. Kind of like turning a voltage on and off to produce a square wave sound. In our case they're mounted to metal plates, which amplifies this in a way similar to a drum. So if you control the rate at which pulses are sent, you can change the note/frequency they produce.
All based on intuition, though, so if someone has a more accurate answer please feel free to pop in.
Unread 21-12-2009, 22:32
techtiger1's Avatar
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
Think of a stepper motor as a servo motor that can spin 360 in increments at a time. D5 nice little unit and good thought of using that to prototype cnc parts. .
-Drew
Team 1251 The TechTigers
2006 Palmetto Regional Winner
2007 Orlando Regional Winner
2008 Orlando Regional Winner
2010 Orlando Regional Winner
Unread 21-12-2009, 23:43
RoboMaster's Avatar
RoboMaster RoboMaster is offline
Alum, former programmer&co-captain
FRC #2472 (The Centurions)
RoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant future
This is fairly related to stepper motor sounds, or at least the theory behind it and how you can purposefully create them. Although, it's interesting, but not actually from normal use.
Stepper motors playing Mario Theme
Music Theory and control behind it
My engineering blog: noeticbrainwaves.blogspot.com
I'm not slacking, my code's compiling
...and I'm using LabVIEW
Unread 21-12-2009, 23:48
Molten's Avatar
AKA: Jason
Thanks all, I was sure someone could explain it terms I'd understand. I'm not so good with tool knowledge, so anytime something can be explained without the assumption that I know a tool...it is most appreciated.
pic: Has anyone seen my teams router?!?!?!? Wayne Doenges Extra Discussion 20 22-10-2009 15:12
EMC linux + CNC mill + CNC Lathe Leav Technical Discussion 8 09-11-2008 23:08
CNC Router/Mill Andy L Technical Discussion 80 03-11-2008 02:14
pic: CNC Patterns R.C. Extra Discussion 5 13-08-2008 15:36
Intelitek CNC Motion - Virtual CNC Machines Kingofl337 Programming 0 19-03-2008 11:29
