Go to Post Spell Check is your friend! - dez250 [more]
Unread 22-12-2009, 10:44
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: pic: Wheel 4 V1.2
Originally Posted by CraigHickman View Post
Erm, yes it does. Please examine the lower wheel closer. The wheels were "dished" out by a .5" radiused end mill, in order to increased the side load ability of each wheel.
It's possible that I'm not seeing something in the picture that you know is there. The extra widening on the ends of the spokes would seem to be helpful only in the normal direction of travel of the wheel. To be stronger in the sideways direction, the spoke would need to be thicker where it meets the hub.
(It's also possible that I don't know what I'm talking about, as I'm more attuned to software than hardware, but I think a couple of seasons of kit wheels from AndyMark did a good job of showing how side load stresses need to be dealt with.)
pic: Pic 2: "caster wheel" crab drive combo adengler Extra Discussion 7 27-01-2009 21:14
pic: Pic 1: "caster wheel" crab drive combo adengler Extra Discussion 1 25-01-2009 17:44
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 17-01-2007 01:21
pic: da wheel CD47-Bot Robot Showcase 11 08-02-2004 22:04
