Go to Post I'm very certain that specifics are quite interesting but all that keeps going through my mind is, "OOOOOH SHINY!" - Andrew Schreiber [more]
Unread 22-12-2009, 18:16
Re: pic: Wheel 4 V1.2
Rion,
In a discussion such as this, most likely everyone has a point that is correct; this does not validate rude comments or the "I told you so!" attitude, especially when directed to some of the most respected (for good reason) mentors in FIRST.
My post was certainly immature, but I have a hard time letting things like that slide.
Yes, radii such as those are good, we do them on our wheels; they can be machined easily with a ball end mill. They certainly help make the part stronger and reduce failure at that joint. However, you can see in the picture's Jon linked that they had a radius, and thin spokes can still fail.
Raul was making a valid point, analyze what kinds of forces are on your wheels before you lighten the heck out of them. No one can say "1/4" thick spokes are strong enough" without knowing the floor surface, wheel tread, drive type, etc.
pic: Pic 2: "caster wheel" crab drive combo adengler Extra Discussion 7 27-01-2009 21:14
pic: Pic 1: "caster wheel" crab drive combo adengler Extra Discussion 1 25-01-2009 17:44
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 17-01-2007 01:21
pic: da wheel CD47-Bot Robot Showcase 11 08-02-2004 22:04
