Go to Post My suggestion is to first focus in on your drive base. Get it running, and drive it into the ground and see what breaks. Then fix it. Rinse wash and repeat. - Andy A. [more]
Unread 22-12-2009, 18:36
Rion Atkinson's Avatar
The CAD Guy
Re: pic: Wheel 4 V1.2
Rion,
In a discussion such as this, most likely everyone has a point that is correct; this does not validate rude comments or the "I told you so!" attitude, especially when directed to some of the most respected (for good reason) mentors in FIRST.
My post was certainly immature, but I have a hard time letting things like that slide.
Yes, radii such as those are good, we do them on our wheels; they can be machined easily with a ball end mill. They certainly help make the part stronger and reduce failure at that joint. However, you can see in the picture's Jon linked that they had a radius, and thin spokes can still fail.
Raul was making a valid point, analyze what kinds of forces are on your wheels before you lighten the heck out of them. No one can say "1/4" thick spokes are strong enough" without knowing the floor surface, wheel tread, drive type, etc.
While you have a point (the "I told you so" attitude being wrong) I have dealt with stuff like this sense I have joined my robotics team. I guess everyone learns in different areas in different times. I do apologize for calling you out on this.
OK. Back on topic.
I honestly have no idea how to use the stress analysis on SolidWorks. Would anyone mind either looking over it for me or giving me a detailed walk through? Also. If I were to add the radii, what degree of a fillet should I put on them?
-Rion
‎‎"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. -Albert Einstein
Start Something
Email - rionatkinson@gmail.com
Skype - Rion.Atkinson
pic: Pic 2: "caster wheel" crab drive combo adengler Extra Discussion 7 27-01-2009 21:14
pic: Pic 1: "caster wheel" crab drive combo adengler Extra Discussion 1 25-01-2009 17:44
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 17-01-2007 01:21
pic: da wheel CD47-Bot Robot Showcase 11 08-02-2004 22:04
