Go to Post The solution to that "problem" is obvious: practice driving. - Alan Anderson [more]
Unread 30-12-2009, 16:55
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
paper: High Speed Optimization Technique
High Speed Optimization Technique by kramarczyk
Unread 30-12-2009, 17:16
boomergeek's Avatar
boomergeek boomergeek is offline
AKA: Mr. D (Dick DiPasquale)
FRC #0241 (Pinkerton Robotics)
boomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant future
Re: paper: High Speed Optimization Technique
This seems to be a valuable spreadsheet for understanding movement mechanics. Thanks for sharing.
I think I did notice an error in it:
In the "AndyMark 2-speed modeling sheet" in the low-gear data: AC140 to AC590 (Robot acceleration) improperly uses that maximum acceleration data (AA column) instead of the actual acceleration data (AB column).
(the same error is in the high gear data, but high gear does not make a difference unless you use very slippery tires).
The end result is that the low gear will seem a little bit faster especially at short distances than it actually is if you try to use it with 4 CIMs instead of 2 CIMs.
Has anyone ever tried to match this simulator to actual data from live robots?
High Speed 3-Fingered Hand EricVanWyk Chit-Chat 4 26-08-2009 18:25
Low Speed High Torque Drive? JHale Technical Discussion 11 18-11-2008 20:15
Free High-speed in St. Cloud, FL Barry Bonzack Chit-Chat 6 08-09-2006 07:28
high speed internet help Ben.V.293 IT / Communications 22 26-12-2004 04:14
