Go to Post [You know you've overdoes on FIRST when...] You're willing to take an 8 AM for the team. - ttldomination [more]
Unread 31-12-2009, 14:42
Re: pic: Chassis Idea
Originally Posted by Formerly Famous View Post
I'd be very weary of the weight you posted for a couple of reasons; You don't have everything modeled (chain, etc..), and even for what you have modeled, 30 lbs seems really light.
1/8" wall 1x1 is around .5 lbs a foot, and based on your 27x37, that puts you at around 17-18 lbs just for the 1x1. Add in two CIMs at 2.75 lbs each and the Gearboxes at 3.5 each and you see it starting to add up; this isn't even counting your mounting plates or wheels.
I'm not criticizing your design, it looks like a decent start to a decent drive. I just want people to realize that the weight a CAD program is the weight exactly as the model is modeled; So, if the model isn't accurate to real life in terms of included properties, applied materials, and custom mass properties (Setting the weight of parts like CIMs), the number won't be accurate either.
For the drive itself, I'd recommend you switch to a good deal of 1/16" wall, switch to dead axles and prioritize a light & robust tensioning system.
pic: Chassis Idea Rion Atkinson Extra Discussion 17 25-08-2009 13:24
pic: Chassis Driving 2 Hanna2325 Extra Discussion 4 12-01-2009 11:13
New AM C-Base Chassis vs. Old IFI KitBot Chassis? ChuckDickerson Kit & Additional Hardware 5 06-01-2009 08:36
pic: 2430 Chassis Boydean Extra Discussion 2 09-02-2008 12:10
New Format - Good Idea/Bad Idea? Harrison Chairman's Award 4 07-11-2002 16:28
