Go to Post I'm not overdosed, I'm not even addicted. I just choose to never, ever, ever leave FIRST. - SL8 [more]
Unread 31-12-2009, 16:04
Rion Atkinson's Avatar
The CAD Guy
Re: pic: Chassis Idea
Okay, that is definitely not 43 lbs.
What you need to do is make sure every component is set correctly. If it's a machined part or metal piece that is a uniform material set it's material in SW, that will make apply the proper density and weight. For everything else go to tools > mass properties > check the box for assigned mass properties, and manually assign a mass. CIMs are 2.75 lbs, compressor ~5, etc... Someone posted a spreadsheet a while back that had most of the electronic's weights. You can do assigned mass properties for an assembly, and ignore the properties of it's components; for example, set the shifters to 3.4 lbs + 2.75 lbs (the weight of a CIM plus the gearbox).
As for trusting parts that have been imported or given to you from others; just don't. If a goal of yours is to use your CAD model to provide accurate weight estimates, get in the habit of making sure all parts are set correctly as they are made and/or inserted into the assembly. It is a horrible experience trying to figure out later on why the robot is 20 lbs lighter/heavier than you think it should be and you have 1000+ parts in the assembly.
Thank you for this! I probably would have been killing myself come build season while working on CAD... Thank you very much. I'm going to get started on changing all the masses.
Originally Posted by ,4lex S. View Post
A Box Drivetrain like this generally looks quite good on its own, but when you consider a real FIRST robot, some flaws pop up. From a structural standpoint, you need to ensure that you will be able to adapt this design to manipulators.
About 50% of the time my team had to take a chunk out of the front of the chassis to facilitate claws or collectors. Just keep this possibility in mind and adapt your design for potential geometry changes.
If you can't get it welded, this design should work quite well with rivets. Triangular corner gussets might be a good idea for some of the pieces, rather than just right angle aluminium.
This is really just my first step in designing a working FRC chassis. I would except part to get chopped up. If they didn't, then the GDC decided not to be evil... (Wouldn't that be the day. )
I have seen pictures of riveted Aluminum chassis so I figured I would be pretty safe in doing so. When I get far enough into the design process I will probably create a CAD with those in it. (Yes rivets and all. I may add wires... )
-Rion
‎‎"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. -Albert Einstein
Start Something
Email - rionatkinson@gmail.com
Skype - Rion.Atkinson
pic: Chassis Idea Rion Atkinson Extra Discussion 17 25-08-2009 13:24
pic: Chassis Driving 2 Hanna2325 Extra Discussion 4 12-01-2009 11:13
New AM C-Base Chassis vs. Old IFI KitBot Chassis? ChuckDickerson Kit & Additional Hardware 5 06-01-2009 08:36
pic: 2430 Chassis Boydean Extra Discussion 2 09-02-2008 12:10
New Format - Good Idea/Bad Idea? Harrison Chairman's Award 4 07-11-2002 16:28
