Go to Post To put it simply: An adult coach impacts a team for two minutes. An adult mentor impacts a team for a lifetime. - dlavery [more]
Unread 31-12-2009, 16:09
Re: pic: Chassis Idea
Originally Posted by ,4lex S. View Post
A Box Drivetrain like this generally looks quite good on its own, but when you consider a real FIRST robot, some flaws pop up. From a structural standpoint, you need to ensure that you will be able to adapt this design to manipulators.
About 50% of the time my team had to take a chunk out of the front of the chassis to facilitate claws or collectors. Just keep this possibility in mind and adapt your design for potential geometry changes.
If you can't get it welded, this design should work quite well with rivets. Triangular corner gussets might be a good idea for some of the pieces, rather than just right angle aluminium.
That's pretty much a given when it comes to designing anything, you need to be able to adapt it to the circumstance. I'm sure Rion knows this already. It is the same with electrical layouts (hence why its funny when people complain about electronics placement in CAD).
pic: Chassis Idea Rion Atkinson Extra Discussion 17 25-08-2009 13:24
pic: Chassis Driving 2 Hanna2325 Extra Discussion 4 12-01-2009 11:13
New AM C-Base Chassis vs. Old IFI KitBot Chassis? ChuckDickerson Kit & Additional Hardware 5 06-01-2009 08:36
pic: 2430 Chassis Boydean Extra Discussion 2 09-02-2008 12:10
New Format - Good Idea/Bad Idea? Harrison Chairman's Award 4 07-11-2002 16:28
