Go to Post As we all know, a low Center of Gravity is a beautiful thing. - Andy Baker [more]
Unread 01-01-2010, 16:50
Gdeaver Gdeaver is offline
FRC #1640
Re: pic: Chassis Idea
Team 104 made a box frame like this the last 2 years. The frame was made out of 8020 Quick Frame 1/16" box tubing. We also used the associated plastic connectors. In a couple of hours we cut and whacked our frame together. We had no failures or structural issues. We did use polycarbonate covering and other structures to tie everything together which is critical. We used dead axles. The axle supports were made from 8020 10 S 8611 double retainer profile . The axle supports clamps onto the frame allowing the chain to be tensioned. For the axle span 3/8" grade 8 bolts work well and save weight. The bottom board also is a structural part of the frame. A piece of 1/4" Baltic birch plywood would be a good choice. To go one step further, laminate the board with a layer of 5.7 OZ carbon cloth on both sides. This type of frame is good for low resource Teams.
pic: Chassis Idea Rion Atkinson Extra Discussion 17 25-08-2009 13:24
pic: Chassis Driving 2 Hanna2325 Extra Discussion 4 12-01-2009 11:13
New AM C-Base Chassis vs. Old IFI KitBot Chassis? ChuckDickerson Kit & Additional Hardware 5 06-01-2009 08:36
pic: 2430 Chassis Boydean Extra Discussion 2 09-02-2008 12:10
New Format - Good Idea/Bad Idea? Harrison Chairman's Award 4 07-11-2002 16:28
