Go to Post The fact of the matter comes down to this: No matter what you are interested in, you can always encourage others. - Amanda Morrison [more]
Unread 02-01-2010, 01:37
Re: pic: Chassis Idea
Originally Posted by IndySam View Post
We machine connectors (like 8020 quick frame) that slip inside the 1" square tube and then use Loctite Hysol to bond them together.
You can hit it with a sledge hammer and the aluminum will give way before the Hysol does.
This isn't that uncommon of a practice guys, and its fairly easy to do even with 1x1 and 1x2 square tubing. We've done it for the past 3 years or so; however, we machine out nylon and UHMW (and even solid aluminum) blocks to insert into the ends of the tubing. Then simply rivet, screw, or bolt the block into place. The ends of the blocks (or wherever you need) are drilled and tapped. The screw or large rivets are easily replaceable with hard epoxy, loctite, or even gorilla glue (in some areas). And there you have a snug fitting frame connector!
pic: Chassis Idea Rion Atkinson Extra Discussion 17 25-08-2009 13:24
pic: Chassis Driving 2 Hanna2325 Extra Discussion 4 12-01-2009 11:13
New AM C-Base Chassis vs. Old IFI KitBot Chassis? ChuckDickerson Kit & Additional Hardware 5 06-01-2009 08:36
pic: 2430 Chassis Boydean Extra Discussion 2 09-02-2008 12:10
New Format - Good Idea/Bad Idea? Harrison Chairman's Award 4 07-11-2002 16:28
