Go to Post Success to me is a feeling that is associated with achieving something you truly worked hard for; something that you can look at and say "That's my best work." - OneAngryDaisy [more]
Unread 04-01-2010, 09:49
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Re: what is the size of the electronics
Pat,
There is a lot to be said for distributing electrical components to minimize the length of wire in high current branches. Often teams will attempt to make things look really nice while causing excessive wire resistance to compromise the operation particularly in auto mode. The addition of 4 feet of #10 wire to one side of your drive can lose you almost 0.5 volts at near stall delivered to your CIM or FP motor. Sometimes it is unavoidable but too often teams forget that pretty isn't always good.
Al
WB9UVJ
www.wildstang.org
________________________
what Chain size and tensioner to use for the drivetrain edBringas Technical Discussion 28 22-01-2008 14:42
What size breaker should I use for the RC? Excelsior Electrical 4 18-01-2006 07:34
What is the actual size of the 12" wheels? Adam Y. Technical Discussion 2 23-01-2004 22:27
the size of the shipping crate, the maximum dimensions?????????? MASherry General Forum 5 13-01-2004 22:30
