Go to Post I'm about to brain myself on a wall in frustration! - pfreivald [more]
Unread 01-08-2010, 12:55 PM
pic: Simple Drive Train Concept
Unread 01-08-2010, 01:01 PM
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: pic: Simple Drive Train Concept
I love the simplicity, very nice.
You could switch to 4" omni's and avoid the sprocket reduction.
If the game doesn't require max traction you could skip the chain to the omni's and really make a simple robust drive.
Well done.
Unread 01-08-2010, 02:38 PM
Rohan J Rohan J is offline
FRC #1540 (Flaming Chickens)
Rohan J has a spectacular aura aboutRohan J has a spectacular aura aboutRohan J has a spectacular aura about
Interesting! I would say that you could you could do a four wheel base, just remove the middle wheels, and as IndySam said, run chain between the two ends, or keep the six wheel base, run chain from the middle to the ends, lower the middle wheels 1/8" and replace the omnis with regular wheels.
Unread 01-08-2010, 03:05 PM
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Overall its nice but I would change a couple things. The first is this design could be simplified by just using a normal toughbox in the middle and then chaining to both outer wheels. It would be lighter as well since it would require half as many gears. Also the way the frame is laid out here gives you a relatively higher center of gravity which could make your robot less stable.
Mentor 2415
Unread 01-09-2010, 09:45 PM
coutantcheese coutantcheese is offline
FLL #2108
coutantcheese is an unknown quantity at this point
Nice. It's simple, looks easy to build, and it's purple.
Is the configuration shown made to be compliant with this year's bumper rules? The largest omnis only have a radius of 4 in, only putting the bumpers about half way high enough for the new bumper rule. "BUMPER ZONE – the volume contained between two virtual horizontal planes, ten inches above the floor and sixteen inches above the floor."
Still like the design, but not sure about bumper height.
Unread 01-09-2010, 10:28 PM
This design was created and posted before kickoff and was not intended to be designed with 2010 in mind. Please read the entire thread before posting.
pic: Simple Drive Failure Boydean Extra Discussion 5 02-15-2009 01:13 AM
Drive Train Components: the inner working parts of a drive train naruto137 Technical Discussion 3 12-10-2008 09:14 PM
pic: Unique drive concept Joe G. Extra Discussion 36 05-12-2007 08:27 PM
pic: 1683 Concept 8 Wheel Drive sdcantrell56 Extra Discussion 16 04-16-2007 02:22 PM
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 03-29-2006 10:16 PM
