Go to Post Weird. On a forum where people talk about robots, we have a robot trying to talk to people. - dellagd [more]
Unread 14-01-2010, 15:56
Sh1ine Sh1ine is offline
FRC #2791
pic: Team 2791 Modular Chassis
Unread 14-01-2010, 15:59
Re: pic: Team 2791 Modular Chassis
I would add standoffs to the bottom and/or make the wheel axles rigid parts of the frame by being a standoff. Currently, they appear to only be rigidly attached on top. You should also probably lighten those rails a bit with some pocketing, there is certainly a lot of meat there.
Unread 14-01-2010, 16:00
rulesall2 rulesall2 is offline
Team Role: Tactician
rulesall2 has much to be proud ofrulesall2 has much to be proud ofrulesall2 has much to be proud ofrulesall2 has much to be proud ofrulesall2 has much to be proud ofrulesall2 has much to be proud ofrulesall2 has much to be proud ofrulesall2 has much to be proud ofrulesall2 has much to be proud of
This is just a prototype, just to clear up some questions.
Racer26 Racer26 is offline
This looks very similar to a "west-coast" style 6wd only with 2 extra wheels.
1075 ran a similarly constructed unit in 2008 offseason at Brunswick Eruption 7, those look like AM Plaction wheels. Are the 2 middle wheels dropped relative to the outside ones?
Unread 14-01-2010, 16:01
Love it.
One suggestion: In our extensive experience with 1/4" plates, it can be overkill and overweight. Have you considered switching to 3/16 or 1/8"? It would allow you to save some machine time with pocketing the 1/4" plates.
Nice job. I really look forward to seeing what comes out from 2791.
Unread 14-01-2010, 16:03
Yes, the middle wheels would be dropped 1/8'' from the outside ones.
Unread 14-01-2010, 16:07
FRC #2791
Yeah I have considered 3/16" Al. Not 1/8", do you think that would be strong enough?
Unread 14-01-2010, 16:26
If you have enough standoffs and in the right plates, you're effectively making a very large I-Beam. If you look at a piece of 4"x4" by 1/8" wall thickness square tubing, the walls seem "thin", but the overall piece is very strong because of it's shape.
You want your designs to be strong by the nature of their shape, rather than just adding more material.
Unread 14-01-2010, 16:31
artdutra04's Avatar
VEX Robotics Engineer
If you have access to sheet metal working equipment, you can cold roll flanges onto 5052 aluminum (don't try this on 6061 unless you have a large bend radius) sheets as thin as .090 to .125 for a base chassis. Team 228 used .125 5052-H32 aluminum for our robot chassis in 2007, 2009 (and soon to be 2010 ) to much success. Here's a photo of our 2009 practice robot frame:
Art Dutra IV
世上无难事,只怕有心人.
Unread 14-01-2010, 16:34
CraigHickman
I like it! Looks like a very solid start. Some things to keep in mind:
-Chain tension. Are you tensioning the chain, or have you run your numbers on sprocket distance?
-Support. How much support do the two plates have between them?
-Live or dead axles?
-How quickly can you repair it if or when it breaks?
Looks like a solid start!
FRC #2791
OK, talking about standoffs I forgot to mention that the axles are going to be standoffs. My content center is not loaded on Inventor but I am going to use 1/2" through bolts for axles, then utilize spacers to keep the wheels aligned.
Unread 14-01-2010, 17:48
Not a bad prototype. Didn't know I had such talented teammates.
Would this be easy to throw AM or laser cut floating tensioners on?
Unread 14-01-2010, 19:01
FRC #2791
Thats the plan.
pic: 2791 Final robot yodameister Robot Showcase 13 21-02-2009 23:45
pic: What is 2791 up to? yodameister Extra Discussion 10 02-02-2009 18:21
pic: Rookie 2791 progress yodameister Extra Discussion 10 27-01-2009 21:45
Team 1583's 6 wheel modular drive prototype NOV8R Robot Showcase 8 08-01-2008 11:57
pic: Team 116 Modular Control System dlavery Robot Showcase 42 21-10-2007 11:15
