Re: pic: Ramp Video
Uh... Section 8, R11 The FRAME PERIMETER must be comprised of fixed, non-articulated structural elements of the ROBOT. The FRAME PERIMETER must remain a fixed, unchanging polygon throughout the MATCH.
http://usfirst.org/uploadedFiles/Com...Robot_RevA.pdf Sorry guys, we had the same idea... |
Re: pic: Ramp Video
Re: pic: Ramp Video
That isn't the frame of our robot though.. so we are perfectly safe.:
Our frame won't have a suspension. |
Re: pic: Ramp Video
FRAME PERIMETER – the polygon defined by the outer-most set of exterior vertices on the ROBOT (without the BUMPERS attached) that are within the BUMPER ZONE. To determine the FRAME PERIMETER, wrap a piece of string around the ROBOT at the level of the BUMPER ZONE - the string describes this polygon.
Re: pic: Ramp Video
Re: pic: Ramp Video
...not that it wouldn't be pretty awesome to see in competition... |
Re: pic: Ramp Video
Re: pic: Ramp Video
As you can see from the drawing the frame is stationary on level ground and does not articulate. When it goes over the ramp the drive system articulates but the frame remains solid. ( the frame is where the bumpers are attached).
Re: pic: Ramp Video
Joe, it seems to me that as the middle wheel goes up, the outer wheels go down. Wouldn't this cause the bumper height to change? Bumpers must remain in the BUMPER ZONE, 10-16" off a level surface.
#10
Re: pic: Ramp Video
Key phrase--"level surface". If the robot is set up on a level surface, are the bumbers in the bumper zone?
#11
Re: pic: Ramp Video
You also have to watch out for your max height.
Don't make the robot 5 feet above the frame, make it 5 feet above the wheel at the lowest point. How they would test this in the box.. I don't know. But still, ask the Q&A if you guys go with it. Awesome drive. |
#12
Re: pic: Ramp Video
The measurement is taken when the robot is on flat floor. We meet all requirements that we have found in the rules. The bumpers are between 10 an 16 inches above the floor when on flat ground. |
#13
Re: pic: Ramp Video
If I was an inspector, I would measure your robots bumpers with all wheels in contact with the floor . Then I would ask you to full articulate the wheels and then measure the bumpers. If at both configurations the bumpers where with in the bumper zone then I would be satisfied. If not then I would turn this down. I am not an inspector nor am I a member of the GDC. You better Q & A this soon before you go farther. From the picture your bumper height appears to be variable and not fixed or static.
#14
Re: pic: Ramp Video
Re: pic: Ramp Video
Everyones bumpers will be out of the bumper zone when going over a bump, so if this thing is legal on the floor it seems fine to me.
| pic: SWAT 2008 Robot--Short Video Clip at http://smithvillehighrobotics.com/video.htm | SWAT1806 | Robot Showcase | 5 | 27-02-2008 14:00 |
| Ramp Driving Video | NOV8R | Robot Showcase | 14 | 13-02-2007 23:49 |
| 1583 Ramp Deployment Video | NOV8R | Robot Showcase | 9 | 11-02-2007 12:09 |
| VIDEO: Our robot VS. the ramp | Cody Carey | Robot Showcase | 9 | 09-02-2006 21:45 |
| Ramp Riot '05 Opening Video | hockeydaisy341 | Off-Season Events | 6 | 02-11-2005 14:24 |
