Go to Post No, but you have access to the most powerful machine tool of all; a telephone. We had zero machining sponsors, now we've probably had over 30 unique shops run parts for us; All we did was ask. - AdamHeard [more]
Unread 14-01-2010, 20:08
FlyingHedgeHog's Avatar
FlyingHedgeHog FlyingHedgeHog is offline
AKA: Jonathan
FlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud of
Re: pic: Ramp Video
Originally Posted by FlyingHedgeHog View Post
FRAME PERIMETER – the polygon defined by the outer-most set of exterior vertices on the ROBOT (without the BUMPERS attached) that are within the BUMPER ZONE. To determine the FRAME PERIMETER, wrap a piece of string around the ROBOT at the level of the BUMPER ZONE - the string describes this polygon.
I think the judges would frown on that, it's kind of lawyer-ing, you know? I mean, the point of that Rule R11 is to prevent you from doing that. I don't think you should do it, as much as I would LOVE to...
Unread 14-01-2010, 20:50
Nuttyman54's Avatar
Mentor, Tactician
AKA: Evan "Numbers" Morrison
Re: pic: Ramp Video
This picture was posted a year ago as a prototype concept. It may or may not have any bearing on what team 1322 is doing this year.
...not that it wouldn't be pretty awesome to see in competition...
Unread 14-01-2010, 22:09
DonRotolo's Avatar
Back to humble
FRC #0832
Re: pic: Ramp Video
Words worth repeating.
Unread 15-01-2010, 07:33
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
Re: pic: Ramp Video
As you can see from the drawing the frame is stationary on level ground and does not articulate. When it goes over the ramp the drive system articulates but the frame remains solid. ( the frame is where the bumpers are attached).
Unread 15-01-2010, 08:30
GaryVoshol's Avatar
Cogito ergo arbitro
Re: pic: Ramp Video
Joe, it seems to me that as the middle wheel goes up, the outer wheels go down. Wouldn't this cause the bumper height to change? Bumpers must remain in the BUMPER ZONE, 10-16" off a level surface.
(since 2004)
Unread 15-01-2010, 08:34
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Re: pic: Ramp Video
Key phrase--"level surface". If the robot is set up on a level surface, are the bumbers in the bumper zone?
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 15-01-2010, 17:56
Brad Voracek Brad Voracek is offline
.999~=1
FRC #0399 (Eagle Robotics)
Brad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of light
Send a message via AIM to Brad Voracek
Re: pic: Ramp Video
You also have to watch out for your max height.
Don't make the robot 5 feet above the frame, make it 5 feet above the wheel at the lowest point.
How they would test this in the box.. I don't know.
But still, ask the Q&A if you guys go with it. Awesome drive.
.999~ (Repeating) is equal to one (1).
Team 399 - Eagle Robotics
Unread 17-01-2010, 21:49
joeweber's Avatar
Coach team 1322
Re: pic: Ramp Video
<r07>The BUMPERS must be located entirely within the BUMPER ZONE when the ROBOT is standing normally on a flat floor,
The measurement is taken when the robot is on flat floor. We meet all requirements that we have found in the rules. The bumpers are between 10 an 16 inches above the floor when on flat ground.
Unread 17-01-2010, 22:26
Gdeaver Gdeaver is offline
FRC #1640
Re: pic: Ramp Video
If I was an inspector, I would measure your robots bumpers with all wheels in contact with the floor . Then I would ask you to full articulate the wheels and then measure the bumpers. If at both configurations the bumpers where with in the bumper zone then I would be satisfied. If not then I would turn this down. I am not an inspector nor am I a member of the GDC. You better Q & A this soon before you go farther. From the picture your bumper height appears to be variable and not fixed or static.
Unread 17-01-2010, 22:35
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Re: pic: Ramp Video
Sure looks like bumper height would remain fixed while on the flat floor as the regs require.
Unread 17-01-2010, 23:26
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
Re: pic: Ramp Video
Everyones bumpers will be out of the bumper zone when going over a bump, so if this thing is legal on the floor it seems fine to me.
2016 Central Illinois Winner. Curie Division finalist
Unread 18-01-2010, 08:01
FRC #1640
Re: pic: Ramp Video
If the robot is flat on the floor and the middle wheel is articulated up, are the bumpers still in the bumper zone? This really needs a Q&A. Also with the bumpers up high this year, robot frames will be subjected to allot more stress than in past years with the low riders. Make sure those supports are robust.
Unread 18-01-2010, 10:50
joeweber's Avatar
Coach team 1322
Re: pic: Ramp Video
If the robot is on the flat floor why would the wheels be articulated up? The articulation is not powered. the wheels follow the floor all the time.
Unread 18-01-2010, 12:03
maltz1881 maltz1881 is offline
maltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant future
Re: pic: Ramp Video
The center Omni's are ALWAYS touching the ground, they never leave the floor. They aren't powered by anything other than the friction on the carpet when the Mec wheels are moving. The bumpers are in a permanet position. If you use the bump to manuvere around the field then no matter what your bumpers are going to change height. Meaning when you are going up your back bumper will be closer to the ground then if you were on level ground and just the opposite when going down the other side. The bumpers are solid and in the correct height while on LEVEL ground!
We have read the rules many many times and the question has been given to Q & A. We have asked many many teams in our area about it and if this is doable. Most agree with us that it is perfectly fine while others weren't sure. We are 99.9% sure that we are correct and would be shocked to see anything differently.
Unread 15-01-2010, 11:06
betsy888 betsy888 is offline
FRC #2713
betsy888 is an unknown quantity at this point
Question Re: pic: Ramp Video
Looks like your center wheels are 2 individual omni wheels per side, each one slaved to either the fore or aft mecanum wheel. So basically the center wheels are commanded to have the same velocity profile as the front/back wheels. Is this accurate?
btw, awesome design and thanks for sharing your ideas. We're a second year team so still need lots of help!
pic: SWAT 2008 Robot--Short Video Clip at http://smithvillehighrobotics.com/video.htm SWAT1806 Robot Showcase 5 27-02-2008 14:00
Ramp Driving Video NOV8R Robot Showcase 14 13-02-2007 23:49
1583 Ramp Deployment Video NOV8R Robot Showcase 9 11-02-2007 12:09
VIDEO: Our robot VS. the ramp Cody Carey Robot Showcase 9 09-02-2006 21:45
Ramp Riot '05 Opening Video hockeydaisy341 Off-Season Events 6 02-11-2005 14:24
