Go to Post Man, Earthquakes all over the place, Volcanos and clouds of ashes, S&Ps down 25 pts! and now 1114 is first seed and going to probably pick 469... yep, id say the end of the world is near - scessama [more]
Unread 15-01-2010, 08:30
GaryVoshol's Avatar
Cogito ergo arbitro
Re: pic: Ramp Video
Joe, it seems to me that as the middle wheel goes up, the outer wheels go down. Wouldn't this cause the bumper height to change? Bumpers must remain in the BUMPER ZONE, 10-16" off a level surface.
(since 2004)
Unread 15-01-2010, 08:34
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Re: pic: Ramp Video
Key phrase--"level surface". If the robot is set up on a level surface, are the bumbers in the bumper zone?
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 15-01-2010, 17:56
Brad Voracek Brad Voracek is offline
.999~=1
FRC #0399 (Eagle Robotics)
Brad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of light
Send a message via AIM to Brad Voracek
Re: pic: Ramp Video
You also have to watch out for your max height.
Don't make the robot 5 feet above the frame, make it 5 feet above the wheel at the lowest point.
How they would test this in the box.. I don't know.
But still, ask the Q&A if you guys go with it. Awesome drive.
.999~ (Repeating) is equal to one (1).
Team 399 - Eagle Robotics
Unread 17-01-2010, 21:49
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
Re: pic: Ramp Video
<r07>The BUMPERS must be located entirely within the BUMPER ZONE when the ROBOT is standing normally on a flat floor,
The measurement is taken when the robot is on flat floor. We meet all requirements that we have found in the rules. The bumpers are between 10 an 16 inches above the floor when on flat ground.
Unread 17-01-2010, 22:26
Gdeaver Gdeaver is offline
FRC #1640
Re: pic: Ramp Video
If I was an inspector, I would measure your robots bumpers with all wheels in contact with the floor . Then I would ask you to full articulate the wheels and then measure the bumpers. If at both configurations the bumpers where with in the bumper zone then I would be satisfied. If not then I would turn this down. I am not an inspector nor am I a member of the GDC. You better Q & A this soon before you go farther. From the picture your bumper height appears to be variable and not fixed or static.
Unread 17-01-2010, 22:35
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Re: pic: Ramp Video
Sure looks like bumper height would remain fixed while on the flat floor as the regs require.
Unread 17-01-2010, 23:26
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
Re: pic: Ramp Video
Everyones bumpers will be out of the bumper zone when going over a bump, so if this thing is legal on the floor it seems fine to me.
2016 Central Illinois Winner. Curie Division finalist
Unread 18-01-2010, 08:01
FRC #1640
Re: pic: Ramp Video
If the robot is flat on the floor and the middle wheel is articulated up, are the bumpers still in the bumper zone? This really needs a Q&A. Also with the bumpers up high this year, robot frames will be subjected to allot more stress than in past years with the low riders. Make sure those supports are robust.
Unread 18-01-2010, 10:50
joeweber's Avatar
Coach team 1322
Re: pic: Ramp Video
If the robot is on the flat floor why would the wheels be articulated up? The articulation is not powered. the wheels follow the floor all the time.
Unread 18-01-2010, 12:03
maltz1881 maltz1881 is offline
maltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant future
Re: pic: Ramp Video
The center Omni's are ALWAYS touching the ground, they never leave the floor. They aren't powered by anything other than the friction on the carpet when the Mec wheels are moving. The bumpers are in a permanet position. If you use the bump to manuvere around the field then no matter what your bumpers are going to change height. Meaning when you are going up your back bumper will be closer to the ground then if you were on level ground and just the opposite when going down the other side. The bumpers are solid and in the correct height while on LEVEL ground!
We have read the rules many many times and the question has been given to Q & A. We have asked many many teams in our area about it and if this is doable. Most agree with us that it is perfectly fine while others weren't sure. We are 99.9% sure that we are correct and would be shocked to see anything differently.
Unread 19-01-2010, 21:55
joeweber's Avatar
Coach team 1322
Re: pic: Ramp Video
Q & A gave us the green light, Yahooo!!!
Unread 19-01-2010, 22:13
JesseK JesseK is online now
Re: pic: Ramp Video
Yep Joe, Update #3 today also green-lighted it. I really look forward to seeing this design in action! Be sure to post some videos of it during competition.
GitHub
Unread 20-01-2010, 09:57
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
Re: pic: Ramp Video
Is that the 45degree angle of the ramp? it looked to shalow, and you should build a real bump if possible because it is much harder to test with out the real thing if you know what i mean.
Every day is a new adventure!!!
Unread 20-01-2010, 10:08
joeweber's Avatar
Coach team 1322
Re: pic: Ramp Video
That picture is from one year ago. You can view a video http://www.youtube.com/watch?v=jQMcw4QNCLI
The video ramp is a 45 degree ramp but we had to cut the corners for the low ground clearence of the 6 inch wheels. We will be using 8 inch
pic: SWAT 2008 Robot--Short Video Clip at http://smithvillehighrobotics.com/video.htm SWAT1806 Robot Showcase 5 27-02-2008 14:00
Ramp Driving Video NOV8R Robot Showcase 14 13-02-2007 23:49
1583 Ramp Deployment Video NOV8R Robot Showcase 9 11-02-2007 12:09
VIDEO: Our robot VS. the ramp Cody Carey Robot Showcase 9 09-02-2006 21:45
Ramp Riot '05 Opening Video hockeydaisy341 Off-Season Events 6 02-11-2005 14:24
