Go to Post You might want to read...the Manual very carefully. . - dlavery [more]
Unread 15-01-2010, 14:31
MaiPrettyPwny MaiPrettyPwny is offline
If it doesn't fit, get a hammer.
FRC #0818 (Steel Armadillos)
MaiPrettyPwny is an unknown quantity at this point
Re: pic: Robot suspension
Could you tell me if I'm looking at this right?
It looks like, to me, that the two wheel assemblies are only connected to the central frame in three points. One on either side of the frame near the rear wheels (the white tube, yes?), and the other on the parallelogram in the front.
If this is true, when that parallelogram "flexes," doesn't it pull the two front wheels in towards each other?
Unread 15-01-2010, 20:32
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
Yes you are correct. For the test robot it did bring the front wheels closer. With this years robot we are not useing the three points, we will use four but they will be above the robot drives.
pic: 6 wheel suspension joeweber Extra Discussion 16 13-11-2008 18:22
pic: 6 wheel drive with a suspension joeweber Extra Discussion 18 07-08-2008 00:49
pic: FRC 1726 suspension MrForbes Extra Discussion 4 22-12-2006 15:57
pic: vex suspension psyco_klown Extra Discussion 9 14-11-2006 22:18
Robot Adaptive Suspension Andrew Blair Technical Discussion 13 09-09-2005 12:02
