Go to Post "When I joined the team, I was told that we'd be in the shop for six weeks. I STILL haven't seen a single boutique, and now they have me dumpster diving for robot parts! I quit!" - EricH [more]
Unread 01-15-2010, 10:31 PM
pic: Prototype Iteration 1
Unread 01-15-2010, 10:32 PM
MrForbes MrForbes is offline
Re: pic: Prototype Iteration 1
In general, straight members are stronger than curved members, right?
but they don't look so nice
Unread 01-15-2010, 10:42 PM
Does the curve provide any significant change in the parabola? Creates more of a wedge, I suppose.
Unread 01-16-2010, 10:49 PM
Since the radius from the axis of rotation to the hole at the bottom is constant, the curve itself doesn't effect the end trajectory.
The idea of the outer curve is that the force of impact of the spring has a way to travel directly to the bottom without it all going directly through the bearing. We haven't figured out exactly how much force will be necessary, yet I'd like to plan to not break the kicker at all. Due to spacial constraints, the top of the kicker cannot be in line with the bottom of the kicker, thus the off angle (~15 degrees) and the curve.
We'll test this out over the next couple of days and see what happens I guess.
GitHub
Unread 01-16-2010, 11:59 PM
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Here is a Soviet-style, brute force suggestion
I would guess you could make the kicker arm out of ugly extruded aluminum that gets beefed up a bit where the axle goes through it and consequently not have to do any fancy machining. Extruded parts like the 8020 products seem plenty stiff enough.
To take much of the lateral force off of the axle, either support the axle right next to the kicker arms; or put a round bulge concentric with the axle into the kicker arm, and use rollers outside that bulge to cradle and support the arm/axle combination.
Unread 01-17-2010, 12:40 PM
That's the proof of concept we did last week; now we're on to the actual design that will be implemented on the bot. There are spacial constraints that prevent us from using a straight bar.
In Soviet Rrrussia, concept, prove YOU!
GitHub
pic: Bomb Squad 2nd Iteration Meredith Novak Extra Discussion 2 03-24-2009 03:47 PM
pic: 3rd iteration swerve Aren_Hill Extra Discussion 5 03-21-2008 07:09 PM
pic: 6WD Design Iteration Madison Extra Discussion 7 01-01-2008 02:00 PM
pic: another iteration Aren_Hill Extra Discussion 8 12-20-2007 01:28 AM
pic: Team 488 Arm Prototype -- Iteration 4 Madison Extra Discussion 1 02-13-2005 01:54 AM
