Go to Post If everyone else in the world is an idiot, you may need to recalibrate your idiotness scale. - GaryVoshol [more]
Unread 17-01-2010, 02:29
professor1212's Avatar
professor1212 professor1212 is offline
NASA Space Grant Intern
AKA: Moheeb Zara
FRC #1212 (The Setinels AKA Holy Hamsters)
professor1212 will become famous soon enoughprofessor1212 will become famous soon enough
Re: pic: Pneumatic Kicker Rev_1
Originally Posted by dlavery View Post
Three suggestions:
1. Try a smaller diameter cylinder. The reduced cross-section means you need less air to actuate the cylinder. For a given charge of air, you will get a faster response (up to a limit, as the high pressure wave through the tubing approaches supersonic speeds). There will be a transition point where the diameter reduction will result in less power transferred to the ball during the impact, but I think you are nowhere near that point yet.
2. Try a lighter hammer. This may seem counter-intuitive, but it works. Talk with your physics teachers about this.
3. Pre-load the lever arm with surgical tubing to augment the striking force of the cylinder.
-dave
We originally had it set with a smaller piston for that very reason. This image is when we were attaching a larger bore size in order to handle a possible surgical tubing augmentation. The smaller piston cant pull back the tubing very far...but that might just be due to our configuration.
As for your second suggestion regarding the weight of the hammer....I'm rather intrigued. We were under the impression the weight was applying a large portion of the force against the ball...
Me: Why are you drilling your shoes?
Abdul: To make them lighter.
"Testtubes and Tesla coils,
clockwork brain 'n' glowing oils,
copper, brass, explosive jelly,
his mechapede policed Old Delhi.
Invented the radio transmitting, too.
Played poker with Theremin, Tesla and Poe.
Harnessed cold moonlight to power airships
and destilled antitoxines from postnasal drips. "
Unread 17-01-2010, 02:31
AKA: Moheeb Zara
sidenote:
dave lavery!!!
You're quite literally AWESOME.
Unread 17-01-2010, 04:30
squeaker114 squeaker114 is offline
FRC0114
AKA: Alycia
FRC #0114 (Eagle Strike)
squeaker114 is an unknown quantity at this point
Send a message via AIM to squeaker114 Send a message via Yahoo to squeaker114
this seems like something i tried but with a shoe. but mine failed.
Squeeker114
Unread 17-01-2010, 08:32
Neo1699 Neo1699 is offline
FRC #1699 (Robocats)
Neo1699 is an unknown quantity at this point
Send a message via AIM to Neo1699
Did you assume that the smaller bore cylinder could not pull back the surgical tubing, or was it tested? Yesterday I found a list of bore sizes, PSI, and the force each one can exert. It can be found here:
http://www.usfirst.org/uploadedFiles...%20Rev%20-.pdf
on page 15.
Unread 17-01-2010, 23:07
rangersteve rangersteve is offline
AKA: Steve
FRC #0931 (Perpetual Chaos)
Team Role: Student
rangersteve is on a distinguished road
Send a message via Yahoo to rangersteve
Your power loss on the metal versus wood may have to do with the placement of the cylinder. It appears that on the wood model the cylinder is positioned to pull the hammer back and get a swing on the ball. While in the metal version it appears to start in contact with the ball and just push it.
987 Kicker Destruction JM987 General Forum 29 23-01-2010 16:46
FRC114 Kicker Teaser James114 Robot Showcase 10 22-01-2010 16:56
Video of Kicker Prototypes falconmaster General Forum 52 18-01-2010 22:43
pic: Pneumatic Kicker Rev_0 professor1212 Extra Discussion 0 17-01-2010 01:15
pic: Team 1501's shooter...errr kicker Wayne Doenges Robot Showcase 9 14-02-2006 14:44
