Go to Post A FRC team without engaged and motivated students is like a car without wheels... it isn’t going to go very far. - E. Wood [more]
Unread 17-01-2010, 14:17
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: pic: 2010 window motor winch
I have to agree with Tom about the great explanation from Joe, but, show some mercy on a software guy and explain the formula use to calculate the 54W below.
TIA
If you are trying to lift a 120lbs motor 3ft in 10 seconds -- that means you need 54 Watts. If you only have 40Watts (the best you can do with 2 window motors at 12V) then you are not going to do that much work (lifting the robot that high) in that amount of time... ...no matter how you gear things...
pic: Vex Winch AdamHeard Extra Discussion 5 16-11-2006 23:30
pic: Sprocket mounting for window motor team222badbrad Extra Discussion 3 22-02-2005 03:06
pic: Team 1293's Window Motor Drivetrain 2 Billfred Robot Showcase 18 03-02-2005 23:33
pic: Team 1293's Window Motor Drivetrain 3 Billfred Robot Showcase 0 03-02-2005 21:20
need window motor pic!! Rickertsen2 Motors 3 04-02-2003 21:50
