Go to Post Do it the good ol' American way and throw money at the problem. In other words, get out of there and call a professional to take care of it. - sanddrag [more]
Unread 17-01-2010, 14:46
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: pic: 2010 window motor winch
Originally Posted by rsisk View Post
I have to agree with Tom about the great explanation from Joe, but, show some mercy on a software guy and explain the formula use to calculate the 54W below.
TIA
Here's one way I came up with 54W:
120lbf * 3ft = 488 J (Work = Force*Distance, there's a conversion factor from lbf-ft to J in here as well. Google Calculator did this conversion for me)
488J/ 10s = 48.8W (Power = Work/Time)
48.8W / .9 = 54 W (Gearbox efficiency)
From what I remember reading here and erring on the side of caution I would use 80% as the gearbox efficiency yielding 61W of power necessary.
Also be careful using 120lb as a weight. A full 120lb robot this year could end up at over 150lb after adding battery and bumpers. Using 150lb and 80% efficiency you need about 76W of power to complete the lift in that time.
pic: Vex Winch AdamHeard Extra Discussion 5 16-11-2006 23:30
pic: Sprocket mounting for window motor team222badbrad Extra Discussion 3 22-02-2005 03:06
pic: Team 1293's Window Motor Drivetrain 2 Billfred Robot Showcase 18 03-02-2005 23:33
pic: Team 1293's Window Motor Drivetrain 3 Billfred Robot Showcase 0 03-02-2005 21:20
need window motor pic!! Rickertsen2 Motors 3 04-02-2003 21:50
