Go to Post I suggested it in brainstorming, but then people threw things at me. Apparently there ARE bad ideas in brainstorming. - Kevin Sevcik [more]
Unread 19-01-2010, 18:01
rob_c rob_c is offline
AKA: Rob
rob_c is a splendid one to beholdrob_c is a splendid one to beholdrob_c is a splendid one to beholdrob_c is a splendid one to beholdrob_c is a splendid one to beholdrob_c is a splendid one to beholdrob_c is a splendid one to beholdrob_c is a splendid one to behold
pic: AndyMark has the Nano; we have the Shuffle!
Unread 19-01-2010, 18:02
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Re: pic: AndyMark has the Nano; we have the Shuffle!
I was thinking about a Toughbox Shuffle as well, for the purpose of direct driving a 6" Mecanum wheel. Looks like you may be doing something similar? If so I'd be interested in what gear ratio you're expecting to use.
Unread 19-01-2010, 18:12
mathman05 mathman05 is offline
None #1308
mathman05 is an unknown quantity at this point
I'm sure this will be the same gear ratio as the AM Toughboxes. It looks like they're using the same gears, they're just using a different housing.
Unread 19-01-2010, 18:22
Neat gearbox. What I like about the Nano is that it's narrow and very strong. Like, Battlebots strong. This gearbox seems to be a bit wider in exchange for a narrower box, though one of the gears protudes. It's probably optimized for its intended use, so i'm going to guess mecanum drive.
Unread 19-01-2010, 19:59
Fe_Will's Avatar
Fe_Will Fe_Will is offline
AKA: Will
FRC #0955 (CV Robotics)
Fe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud of
Why not use a Banebots P80 gear box? It would be smaller, more compact, and more efficient.
"It is the mark of an educated mind to be able to entertain a thought without accepting it." -Aristotle
Unread 19-01-2010, 20:30
First thing that comes to mind is a cantilevered wheel, but if you're doing that then the Nano would be perfectly adequate and strong.
Unread 19-01-2010, 20:41
craigboez's Avatar
Mechanical Engineer
We're just trying to avoid the $450 investment in Banebot transmissions. They'd definitely do the trick, but since we don't have any and we do have several Toughboxes we're looking for a more economical solution that uses parts we already have.
Also, aren't planetary gears less efficient than spur gears? I couldn't find anything too official, but this
website seems to agree.
Unread 19-01-2010, 20:45
craigboez's Avatar
Mechanical Engineer
I didn't (couldn't) count the teeth, but it could also easily be one of the optional gearing configurations that AndyMark offers. I was specifically looking into using their 8.45:1 setup. From what I've read that would be a good ratio for a relatively fast bot running on 6" mecanums.
Unread 19-01-2010, 21:04
Fe_Will's Avatar
AKA: Will
Originally Posted by Wikipedia
Advantages of planetary gears over parallel axis gears include high power density, large reduction in a small volume, multiple kinematic combinations, pure torsional reactions, and coaxial shafting. Disadvantages include high bearing loads, inaccessibility, and design complexity. The planetary gearbox arrangement is an engineering design that offers many advantages over traditional gearbox arrangements. One advantage is its unique combination of both compactness and outstanding power transmission efficiencies. A typical efficiency loss in a planetary gearbox arrangement is only 3% per stage. This type of efficiency ensures that a high proportion of the energy being input into the gearbox is multiplied and transmitted into torque, rather than being wasted on mechanical losses inside the gearbox.
Another advantage of the planetary gearbox arrangement is load distribution. Because the load being transmitted is shared between multiple planets, torque capability is greatly increased. The more planets in the system, the greater load ability and the higher the torque density.
The planetary gearbox arrangement also creates greater stability (it's a balanced system) and increased rotational stiffness.
FYI
Unread 19-01-2010, 21:56
What I like about the Nano is that you can support the weight of the drive train through it since it's an enclosed box extrusion. This allows for very compact direct-drive designs which are particularly useful for omni and mecanum drive trains. This one looks perfect for an arm though.
GitHub
Unread 19-01-2010, 22:30
Mr. Ivey's Avatar
Mr. Ivey Mr. Ivey is offline
Mark Ivey
AKA: Mark
Mr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of light
Send a message via AIM to Mr. Ivey
The Shuffle is an AndyMark ToughBox, but configured differently. This year we are in somewhat of a budget crunch, and Rob was looking for a way to save some money. After going through our shelves of parts and finding a bin full of random gears, and a bin of AM ToughBox cases, we realized we had about 6 ToughBoxes. Not being able to use the full size TB this year we were going for the Nano, but that was an expensive investment this year. So we took some 3/8 lexan, found all the bearings and bits to the original ToughBox systems, and a few hours later we had the Shuffle! Amazingly the prototype we build was all by hand, and it works unsettlingly well for a hand built gear box. Hopefully Rob and the rest of the team will be posting more soon.
Ivey
When you tell a student not to do it, you shouldn't do it. Or else you will wind up with a 3/8" drill bit in your finger... Like I did...
Put Your Ipod (or MP3 player) in Shuffle and List the FIRST 25 Songs (be honest) Koko Ed Chit-Chat 461 23-05-2016 20:25
pic: I love the nano Akash Rastogi Extra Discussion 6 02-11-2009 18:19
AndyMark products has been great. . . wsansewjs Kit & Additional Hardware 11 14-08-2007 12:42
**FIRST EMAIL**/Welcome to the 2006 Junior FIRST LEGO League Nano Quest Season!! KathieK FIRST E-Mail Blast Archive 0 27-07-2006 14:54
Has any of the other regional events have a sickness like at the VCU?? Alex Cormier Regional Competitions 28 20-05-2005 14:46
