Originally Posted by Jared341
I am curious - what made you decide to build such a small chassis? (looks to be no more than 22" long, and ~20" wide).
It is 26x19" we made it small so it would be more annoying to other robots
[quote=squirrel;902171]Look close, you can see sprockets on the outside of the end wheels, which will likely be used to connect them together with a long chain.
all six wheels will be powered, we just did not have the sprockets in stock at the time lol
Originally Posted by Taylor
I'm more interested in the contraption behind the table. Care to describe it?
its our mascot
Volty Mcnut
Originally Posted by squirrel
Looking further....it appears the center wheels will be driven directly off the toughboxes, from the other of the double sprockets. Neat design.
you are correct sir.
Originally Posted by sdcantrell56
I know this isnt the finished chassis but I would seriously consider beefing up the rear part of the frame where you have the cutouts. By removing the legs of the channel it will want to bend at that point. Perhaps look at putting a belly pan underneath the entire chassis out of 1/4" baltic birch.
we just bolted a 1/8th alluminum plate to the bottom, we also will have a super-structure to tie everything together, and it will also be completely welded*
not only will it go under the tunnel, but it Will climb the bump
Adam Spears
2010: Goveners Award.
2010: UL Saftey award.
