Re: paper: CG Migration of Robot Crossing Bump using Powerpoint
This is an awesome resource to show younger members (and some veterans) the effect of COG on bump crossing.
I also love the humor, one of the Engineers at my job and I got quite a laugh out of the robot face plant. Thank you. |
Really sweet powerpoint!
Also, did you consider that the wheel base for most robots will not be so continuous? As in, there will probably be a gap in the middle (4 wheeled bot) and it would force the "crest" moment to be a lot sooner, possibly enough to get away with a high CG robot... But I assume this was mainly for your team, and your team has chosen treads, so thanks for sharing with us! |
"I chose to present the tank as it has the most impressive Transistions"
Theatricality - I like it ![]() |
For those that are wonder where their CG will end up, take a look at http://www.chiefdelphi.com/media/papers/2048
It allows both weight budgeting and CG estimation. You can use this to get an estimate before the CAD modeling gets too far along. 10-20 minutes spent now on budgeting can save hours (or even days) of rework. I apologize that the user interface is not slicker and am open to suggestions for improvement. |
Excellent graphical presentation. I would like to suggest a more correct terminology usage. The center of gravity does not change (unless you have moving components), the Moment of gravity is what is being depicted by the vector. This, along with center of mass, is used in aircraft and ship stability calculations also.
Pretty cool paper. It is a great visual way to demonstrate CG. I like it.
-John |
| White Paper Discuss: Cost Effective Robotics: Using Vex in FRC | artdutra04 | Extra Discussion | 2 | 09-01-2006 01:47 |
| White Paper Discuss: Increasing A/D Resolution Using Noise | CD47-Bot | Extra Discussion | 7 | 12-10-2004 09:26 |
| White Paper Discuss: Using an Operator Interface with the 2004 EDU RC | CD47-Bot | Extra Discussion | 6 | 20-01-2004 21:11 |
