Go to Post All I need now is a plow atachment for this year's robot - team 3311 [more]
Unread 20-01-2010, 22:10
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Re: pic: RoboLancers 321 Teaser
Curious if you have tested this chassis on a hump? 1745 found that with six inch wheels that the front of the frame hit the bump on the way up and then the rear frame dragged after you pushed the front wheels up the ramp leaving the rear wheels to lose contact with the carpet. It looks like you have 8 inch wheels so this may not be an issue but, if you can test this on a hump.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
321 @ Philly Regional Justin M. Robot Showcase 1 30-03-2007 22:42
Team 321 Update - Chassis Pic Justin M. Robot Showcase 8 29-01-2007 14:03
Team 321 Teaser #1 Justin M. Robot Showcase 9 25-01-2007 23:34
pic: 111 Teaser (tiny teaser) CD47-Bot Robot Showcase 15 04-03-2003 00:49
