Go to Post to have someone honored as being honered next to us is a huge compliment thank you lol - Aren_Hill [more]
Unread 21-01-2010, 13:01
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
FRC #0842 (Falcon Robotics)
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
pic: 842 Falcon Robotics BreakAway Bot img.3
Unread 21-01-2010, 13:02
powerkane's Avatar
powerkane powerkane is offline
AKA: Earl Colter
FRC #0858 (Delphi Demons)
powerkane is an unknown quantity at this point
Send a message via MSN to powerkane
Re: pic: 842 Falcon Robotics BreakAway Bot img.3
looks like you are using metal bumpers? or are they the mounts for the bumpers?
Unread 21-01-2010, 13:04
EricH EricH is offline
I'm guessing bumper mounts. Guessing they're actually fiberglass (and same for the chassis).
If those were metal bumpers, and the only bumpers they used, then they would have no chance of passing inspection.
Unread 21-01-2010, 13:11
coldfusion1279 coldfusion1279 is offline
AKA: Mike
FRC #1279 (Cold Fusion)
coldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud of
Looks like you have decided to stick with the tunnel route? A good choice if you ask me. Very clean looking chassis. Beautiful.
Cold Fusion's 10th Season
Unread 21-01-2010, 13:12
powerkane's Avatar
AKA: Earl Colter
yep i know that's why i was asking just trying to be helpful and are you sure its fiber glass it looks metal to me, also maby the wheels for driving across the bridge? because the way they are set.
Unread 21-01-2010, 13:20
Metal doesn't have that fiber pattern or tan color. Add that to the fact that 842 is known for use of fiberglass as a frame component, and I would be greatly surprised if it wasn't fiberglass pultrusion. Any metal that big would probably have speedholes by now, too.
Unread 21-01-2010, 13:24
Joining the 900 Meme Team
FRC #0079
They also say it is pultruded fiberglass in one of their other pictures.
Looks nice and clean 842. Maybe I'll make it to your pit in Atlanta to check it out. Good luck.
Unread 21-01-2010, 13:28
powerkane's Avatar
AKA: Earl Colter
right my bad lol I'm not good by telling things by picture
Unread 21-01-2010, 13:43
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Please correct my errors in vision or understanding, but don't the mecanum wheel rollers need to be inline with the diagonals? If so, it appears to me that you need to swap front to rear. Or does it work out the same either way??
or
I question myself because 842 is such an engineering power-house and innovator.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 21-01-2010, 14:37
TheOtherGuy's Avatar
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
You're right, the back two need to be swapped so that there is an X pattern from the top.
Looking good, 842! how many kickers are you planning for?
Unread 21-01-2010, 14:39
Alex Cormier's Avatar
www.TwoPencilDesigns.com
FRC #1405
or
Well the best way to make the mecanum wheels to work is to get the rollers in a X pattern. Unless 842 has come up with some new way to harness the power?
Unread 21-01-2010, 14:40
MrForbes MrForbes is offline
is the quick check to see if you can spin the robot about it's center, on it's rollers? if so you have them backwards.
Unread 21-01-2010, 14:50
falconmaster's Avatar
AKA: Ledge
They are not permanently on there they were just slipped on for the pic... nice to know you guys pay such close attention!
Faridodin "Fredi" Lajvardi KD7WKD
Unread 21-01-2010, 14:57
Yeah, you gotta have thick skin to post pictures here
Unread 21-01-2010, 15:10
AKA: Ledge
Its a great place to find out how wrong "you" are!
pic: 842 Falcon Robotics BreakAway Bot img.2 kE7JLM Extra Discussion 15 21-01-2010 12:43
Congratulations Falcon Robotics FRC 842 Tottanka Chairman's Award 23 23-04-2008 19:42
Falcon Robotics Team 842 kE7JLM Website Design/Showcase 2 08-02-2008 23:20
Team 842 Falcon Robotics Pictures kE7JLM General Forum 0 04-11-2007 12:06
pic: Falcon Robotics 842 Entry in the MATE ROV Championships falconmaster Extra Discussion 1 16-01-2005 12:52
