Go to Post Naw, basketball isn't nearly as great a sport as FRC. They play for the money. We play for honor, dignity, and respect. - synth3tk [more]
Unread 22-01-2010, 04:04
rob_c rob_c is offline
AKA: Rob
rob_c is a splendid one to beholdrob_c is a splendid one to beholdrob_c is a splendid one to beholdrob_c is a splendid one to beholdrob_c is a splendid one to beholdrob_c is a splendid one to beholdrob_c is a splendid one to beholdrob_c is a splendid one to behold
pic: 2108 Swerve Drive
Unread 22-01-2010, 04:06
lenny8's Avatar
lenny8 lenny8 is offline
Aww Yea
AKA: L-Deezy
FRC #1018 (Robodevils)
lenny8 is a splendid one to beholdlenny8 is a splendid one to beholdlenny8 is a splendid one to beholdlenny8 is a splendid one to beholdlenny8 is a splendid one to beholdlenny8 is a splendid one to beholdlenny8 is a splendid one to behold
Re: pic: 2108 Swerve Drive
about how much is that gonna weigh? other that that very nice.
Learn something, Know Something, Do something
Unread 22-01-2010, 07:43
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
Looks nice!
Just one little question. What reduction (if any) do you have going from the window motor to the wheel? [Looked at the picture again and it looks like its about 1:1] If its too much of a reduction, your wheel's turning will be so unresponsive that it will be difficult to truly utilize your swerve. On the flipside, if your reduction is too little, that poor little motor won't be enough to do the job.
The reason I mention this is because we used a window to steer last year. The wheels were extremely responsive (1:1 ratio off motor), but the motor did feel the beating, getting hot and eventually tripping the internal heat breaker (who knew it had one of these?). Granted, it was 1 window to steer 2 wheels at once, and it took at least 30 minutes of practice before we encountered this problem, but remember that it was also slick wheel on slick surface. I see that you plan on using a high traction wheel (on carpet).
The design looks extremely robust, although its a little difficult to tell how thick all those plates are. Maybe there's a little excess material? Of course, if weight isn't an issue, then who cares?
Overall very nice design. Out of curiosity, you don't plan on climbing the ramp, do you?
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
Unread 22-01-2010, 08:03
Gdeaver Gdeaver is offline
FRC #1640
Where is the position sensor mounted and what are you using for it?
Unread 22-01-2010, 08:09
yoshibrock's Avatar
yoshibrock yoshibrock is offline
Mechanical Magician
AKA: Brock
FRC #0540 (Talon)
yoshibrock will become famous soon enoughyoshibrock will become famous soon enough
Send a message via AIM to yoshibrock
This is awesome! We considered a swerve for a little while before deciding on mechs since we used them fairly well in 2007
We'll see you guys at VCU, right? Maybe we'll find ourselves on the same alliance again.
There is no charge for awesomeness.
Am I a hero? I really can't say, but yes.
Unread 22-01-2010, 11:06
Mr. Ivey's Avatar
Mr. Ivey Mr. Ivey is offline
Mark Ivey
AKA: Mark
Mr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of light
Send a message via AIM to Mr. Ivey
Good Morning,
Since Rob is in class I will take a moment to answer a few of the questions.
Answer is there is no reduction. The teams experience from using this motor last year, is that it is a respectably durable piece of equipment. We used it to run our spindle last year, so we know it can take a beating.
I will leave that up for Rob to tell. It's his design, and knows what the limitations are better than I do. I need to sit down with it some more this afternoon and go over it.
We haven't quite figured out where we are going to add it. Also the students are trying to figure some programming thing out for it that they want to do special.
Of course! Wouldn't miss it. We will be at VCU, the new North Carolina Regional, and Atlanta this year!
Ivey
When you tell a student not to do it, you shouldn't do it. Or else you will wind up with a 3/8" drill bit in your finger... Like I did...
Unread 22-01-2010, 15:52
BlackBird11891's Avatar
BlackBird11891 BlackBird11891 is offline
We Rise Above Our Challenges
AKA: Chad Krivanec
FRC #1927 (Team Tempest)
BlackBird11891 is on a distinguished road
this looks fairly close to what we at 1927 used last year only compacted together
Unread 22-01-2010, 17:58
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
How is the wheel module held on? Without seeing the bearing/plate mount, I can't tell if this advice will be useful or not, but here it goes. Have you thought about having supports on the front and back between the two side plates? They aren't strictly necessary, depending on how you've set everything up, and with that thickness aluminum, it should be fine either way, but on the other hand, it's a nasty bump...
Otherwise, nice compact design, I like the setup!
Unread 23-01-2010, 20:26
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Unless you want to have 1 motor drive more than 1 wheel, integrating the drive motor and transmission into the crab pod might save space and possible a little weight too (less of that giant plate). We had 2:1 window motors last year for the rear pods on our robot (two motors for two wheels, the front two had Globe motors), and they worked very well. We also had ~3:1 reduction from window motors on a crab-drive system in 2005. It worked, although we didn't end up using it because moving sideways with a tetra led to instability. Also, you should be able to turn down the window motor coupler and fit a sprocket on it, then drill new holes and bolt it to the coupler, no need for that shaft on top. Then you can mount the potentiometer to the shaft mount on the coupler, with a keyed ring (to change size) and a set screw.
Kettering Motorsports
Unread 23-01-2010, 23:03
Tytus Gerrish's Avatar
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
AHH MAN! I didn't even think about crab with the 4 window motors and 5 CIM's this year. it's like the jeep hurricane concept. im just mad that it didn't even occur to me before. I hope i get to Be your robot Inspector.
EDIT: (Explicit link content warning) ALSO! its easy to remember your team number because J-ROC from Trailer Park Boys made an "album" named 2108 in the Special Say goodnight to the bad guys that wrapped up the series and transitioned into the latest movie Countdown to liquor day.
Last edited by Tytus Gerrish : 23-01-2010 at 23:26. Reason: more info on the fly after the fact
Unread 24-01-2010, 23:49
VanMan's Avatar
VanMan VanMan is offline
NCSU student
AKA: David VanLeeuwen
no team (Team Awkward Turtle)
VanMan will become famous soon enough
Send a message via AIM to VanMan
It looks great rob, I hope it works well.
2010-present - NC State University Underwater Robotics Team
ncsurobotics.com
2007-2009 - FRC 2108
2006 - FRC 926
Unread 11-04-2010, 22:59
NyCityKId's Avatar
NyCityKId NyCityKId is offline
That Weird Kid
AKA: Andre Dunkley
FRC #1601 (Quantum Samurai)
NyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to behold
Send a message via AIM to NyCityKId
I may be a little late with this response but how do you keep the part that rotates on the vertical axis (the wheel), firmly attached while allowing it to rotate freely? I'm trying to design a crab drive module of my own and this is the part that I'm stuck on. I know there is a way to do it but I don't really know how. Every way I come up with seems inefficient. Thanks in advance.
-Andre
pic: Dual Wheel Swerve-Drive =Martin=Taylor= Extra Discussion 5 28-04-2007 01:21
pic: Team 108 - LEGO swerve drive zander_108 Extra Discussion 8 10-04-2007 22:36
pic: My first Lego Swerve Drive Ken Leung Extra Discussion 5 16-08-2006 23:56
pic: Coaxial Swerve drive, lightened. CraigHickman Extra Discussion 19 22-06-2006 15:00
pic: Lego Swerve Drive CD47-Bot Robot Showcase 14 26-06-2003 16:19
