Go to Post The final product, the inspiration, it all that matters. Awards and championships are just bling. - artdutra04 [more]
Unread 24-01-2010, 17:17
engunneer's Avatar
engunneer engunneer is online now
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
engunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond repute
Re: pic: Lightened Gears
Originally Posted by Greg McKaskle View Post
But can I just point out that teams shouldn't try to lighten the cRIO. It will not pass inspection. One last year had fifty holes drilled into the magnesium cast housing.
back in 1999, our robot had a 'net' made of 1/32" lexan strips, 1" wide. There were over a dozen linear feet of these strips. I was one of the team of students that used an industrial hole punch to knock out as much weight as possible from those strips (yes, we had gotten down to that). We punched about 2000 holes in a hexagon pattern by hand.
we also trimmed all the clear parts of our logo out of the 1/32" poly sheets they were glued to, saving another few ounces.
I also recall that we used hanging scales that year, two of them to weigh the whole robot. We were still overweight by 6 lbs a day before ship, the team went back to work trying to find more things to remove, and then I noticed that we tared the scales right side up, but used them upside-down (including the weight of the scales in the robot measurement). Since they were borrowed from the shop at the power plant, they were exactly a kilo each, so I saved us 4.4 lbs. The remaining 1.6 pounds meant the loss of a mechanism, though (we had two ways onto the puck that year, and removed one).
Student FRC23 (1996-1999), Mentor FRC246 (2000), Mentor FRC1318 (2007-2009), Mentor FRC93 (2011), Mentor FRC2151 (2012), Mentor FRC23 (2013), Mentor FRC4761 (2014-2017)
1998 - National Chairman's Award and Woodie Flowers Award (FRC23, Mike Bastoni ) | 2007 - PNW SF (488, 1595) | 2008 - Oregon RCA - Seattle #2 Seed, SF (488, 1696) | 2009 - Oregon #1 Seed, Winners (1983, 2635) - Seattle SF (945, 2865) - Galileo #2 Seed, SF (973, 25) | 2012 Midwest F (111, 71) | 2014 RIDE Winners (78, 125), Inspector - NEU #24, QF (3479, 3958) - NECMP #35 | 2015 Reading #11, SF (1058, 190), Inspector - RIDE #17, QF(4055, 5494), Inspector - NECMP #57 | 2016 Reading #4, SF (133, 4474), DCA, Inspector - Ride #22, SF (1735, 2067), Creativity, Inspector - NECMP #48, RCA - Archimedes
pic: 254/968 Machined Gears Cory Extra Discussion 13 25-02-2008 18:58
pic: Coaxial Swerve drive, lightened. CraigHickman Extra Discussion 19 22-06-2006 15:00
pic: Helical Gears? Joe_Widen Technical Discussion 8 15-06-2006 14:59
pic: Drilled out gears Iain McLeod Extra Discussion 10 06-02-2005 06:41
