Go to Post The only thing I am learning from this thread is the difference between who is arrogant enough to objectify their own interpretations and who is wise enough to question their own interpretations. - Michael Corsetto [more]
Unread 01-25-2010, 12:04 PM
pic: Robot Bump Analysis
Unread 01-25-2010, 12:12 PM
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Re: pic: Robot Bump Analysis
Do you have a graph or another sort of worst/best case comparison graphic that would illustrate the difference in the path/orientation of the body of the robot when it is equipped with the pivoting wheels vs single wheels at the pivot points?
Maybe a graph of degrees of tilt vs the location of the CG (projected onto the floor) as it moves from one side of the bump to another?
That would really ice the cake for folks who want to make a comparison.
Blake
Unread 01-25-2010, 01:54 PM
Blake
Folks who want to make a comparison should probably do their own bump analysis with their specific wheel base and then determine their clearances/weight distribution based upon their own chosen manipulators. It's pretty easy; you don't even need the exact detailed nut-and-bolt model of the drive train.
GitHub
Unread 01-25-2010, 03:29 PM
Tanner's Avatar
Tanner Tanner is offline
FRC #1261 (Roblions)
Tanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to behold
What'd you make those models with? They're quite nifty.
Our team thought of another way using Inventor models of the bump and various robot designs and printing the bump on paper while the robot designs on transparencies. Not exactly rocket science, but our team members seemed to like the new perspective.
I wish I could find a nice way to do dimensionally correct physical simulations, but I can't really find any.
-Tanner
Unread 01-25-2010, 03:38 PM
All you need is a 2D CAD sketch with proper tangent constraints. Then you can drag it around, change dimensions, and see if you'll hit.
Unread 01-26-2010, 02:16 PM
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Google Sketch Up would do this for you.
paper: CG Migration of Robot Crossing Bump using Powerpoint IKE Extra Discussion 7 01-30-2010 10:55 PM
pic: Two men in a bump joeweber Extra Discussion 3 01-18-2010 06:30 PM
pic: Our design on the bump joeweber Extra Discussion 13 01-16-2010 11:14 PM
pic: The IRI Bump Greg Marra Extra Discussion 2 07-26-2008 02:59 AM
1501 Control System Basics and Analysis of a Bipedal Robot Chris_Elston Programming 1 12-25-2005 12:52 PM
