Go to Post Apparently he felt that wearing ringers is akin to "being surrounded by safety." - DanDon [more]
Unread 28-01-2010, 01:58
wedellm's Avatar
wedellm wedellm is offline
Teacher/Mentor
FRC #1158 (EagleCorps Robotics)
wedellm is an unknown quantity at this point
pic: Team 1158 Teaser
Unread 28-01-2010, 02:03
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Re: pic: Team 1158 Teaser
This isn't much of a Teaser as much as a drive train design.
Even still, good design, I wonder how well those piston shock absorbers work. This should be very interesting if/when this design finishes production.
-Mentor-
-UMass Lowell '13-
-Former Team Lead-
Abrakadabra Abrakadabra is offline
Here We Go !!!
AKA: Scott Kukshtel, Mr. K
FRC #3467 (The Windham Windup!)
Abrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant future
If those are standard pneumatic cylinders acting as shocks, I think that Team Update #5 may have just made that particular use illegal, even if they are planned to be operated in a totally closed manner.
Our team was considering doing something similar, but now we are rethinking it. Team Update #5 modifies rule <R72-I> to add the word "COTS" between "closed-loop" and "pneumatic":
I. For the purposes of the FIRST competition, closed-loop COTS pneumatic (gas) shocks are not considered pneumatic devices, and are not subject to the pneumatic rules (although they must still satisfy all other appropriate rules).
Standard pneumatic cylinders cannot be be considered "COTS shocks" because that is not what they are really designed for. So now, even though they may be operated in a "closed-loop", they have to be considered part of the pneumatics system and are subject to the pneumatic rules, the primary one of which is that all "working" pressures must be no greater than 60psi.
Although you may pressurize the cylinders to much less than 60psi, there is no way to guarantee that a sudden drop or bump won't raise the pressure in one end of the cylinder to over 60psi due to simple mechanical force.
One possible way to satisfy this rule would be to have the top sections of all four cylinders connected to a pressure relief valve that would provide relief above 60psi (and probably add a pressure gauge as well to satisfy inspectors). However, there are still many grey areas in such a setup, and it could still be deemed an "out-of-spec" (i.e. illegal) use of the pneumatic components.
What does the community think?
Unread 28-01-2010, 03:40
SpaceOsc's Avatar
SpaceOsc SpaceOsc is offline
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
SpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant future
Send a message via AIM to SpaceOsc Send a message via Yahoo to SpaceOsc
i doubt a pneumatic piston ceases to be pneumatic just because its closed, seems like the spirit of the rule might discourage the use of gasses other than whats in air.
2014-2017: Team 4501 Coach/Lead Mentor
2002-2011: Team 702, Mentor
2001-2002: Team 702 Captain
Unread 28-01-2010, 08:22
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The pressure regulators we've used in the past are "relieving regulators" and indeed prevent back-pressurization from mechanical force on the pistons. I don't see anything wrong here at all.
Unread 28-01-2010, 10:19
I'm not complaining
I'm excited to see how you guys get this to turn on a dime. I think I can see how it will be done, and it would be really cool to see it work.
This is a lot like a drive I wanted to try this year.
Team 1158 "The Corps" Webpage JDeCola Website Design/Showcase 0 17-02-2009 11:21
Team 1671 Thanks Alliance partners Team 1538 & Team 1158 Given To Fly Thanks and/or Congrats 0 10-03-2008 00:06
Eagle Corps 1158 Website wedellm Website Design/Showcase 2 14-02-2008 09:50
pic: Team 1053's very first ever teaser pic CD47-Bot Robot Showcase 3 16-02-2004 22:56
1158 our bot Raul@13 Robot Showcase 5 14-02-2003 19:54
