Go to Post Every freshman or first time FIRST student comes onto the team with little to no experience. The whole point is that you will get to learn how to do some new things. - engunneer [more]
Unread 01-02-2010, 15:32
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
Re: pic: Team 1388: Teaser 2
The robot is from 2007 .. hence the maxi block. It just happened to be similar to our 2010 base, and have a removable arm, which made interfacing the prototype arm easy.
As for the vice, you can make your own conclusions .. but was just for making the weight more accurate without the old arm on the bot.
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
pic: Team 1388: Teaser time. Mike Hendricks Extra Discussion 13 01-02-2008 00:18
Team #1388 teaser TURBO (1388) Robot Showcase 6 30-01-2008 14:33
pic: Team 1388 Arm Teaser Garth1388 Robot Showcase 11 02-05-2007 19:03
pic: Team 1388 Teaser #2 jgannon Extra Discussion 7 03-02-2005 02:05
pic: Team 1388 Teaser Mike Hendricks Extra Discussion 10 27-01-2005 10:28
