Go to Post Why, yes. I do use Windows, why do you ask? - dtengineering [more]
Unread 02-02-2010, 03:19 PM
REVving up for a new season
FRC #2848 (All-sparks)
Re: pic: Wave Robotics Drive Teaser
Originally Posted by Tom Line View Post
That is an awesome design. I'm curious - when you're driving on flat ground, how to you insure that your bumper stays in the mandatory bumper zone? Obviously you must be using some type of automated articulation.... pneumatics perhaps?
Why would they need to have some automated articulation to accomplish this? Assuming they have 2 modules on either side pivoting like they are, the distance to the bumper from the pivot is fixed so no control would be necessary on flat ground since the axis through the pivots would be parallel to the ground
Greg Needel│www.robogreg.com
Unread 02-02-2010, 03:51 PM
Jamie Kalb Jamie Kalb is offline
Jamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to all
Um ... I don't get it. Yes, the pivot point is at a fixed hight, but, without active articulation, doesn't the bumper frame pivot like a seesaw on that pivot point? And is there some rule that I missed that makes that legal?
I'm sure you guys have already figured this out, I'm just trying to catch up.
Team 3129 Green MacHHHHine Founder, Captain (2009-10), Alumnus, and Mentor (2011-14)
2011-13 VEX World Championship...
Unread 02-02-2010, 04:15 PM
hillale's Avatar
hillale hillale is offline
Formerly a Winnovator
AKA: Alec Hill
FRC #3617 (Cold Logic)
hillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to behold
Send a message via AIM to hillale
It's hard to tell by the pic, but the size is a left up to interpretation. I'm guessing they have 4 total modules, but with the aspect of the picture it's hard to tell and they might just have 2 modules (one on each side) implying the "see-saw" effect J-rizzle is talking about.
Unread 02-02-2010, 04:57 PM
Oh! Gotcha. Good clarification.
Unread 02-02-2010, 09:50 PM
Mark Holschuh's Avatar
Mark Holschuh Mark Holschuh is offline
FRC #2194 (Fondy Fire)
Mark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud of
It looks great! Obviously you have access to more machine equipment than your team had last year. We're looking forward to seeing it sometime soon at the EAA.
Unread 02-02-2010, 10:52 PM
Tyler Olds Tyler Olds is offline
FUN Show Host
no team (First Updates Now)
Tyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond repute
Thanks for the compliments and questions, I will try to do my best with some answers!
The drive is made of a "longitudinal walking beam" rigid module on both sides and pivots sing a shaft with two bearings. The suspension is composed of springs and dampers using a pneumatic cylinder that is pressurized. To reduce the weight of putting a compressor on the robot and to counter-act the “see-saw” effect, we are using a linear actuator that will lock the suspension in place when traveling on flat ground. To help with going up the bump diagonally, we decided to use Omni wheels (double wide on each side) on the backside of the robot. The effect of this is whenever we go over a bump at an angle; the robot will actually center itself automatically. It does work if we go over backwards, but not as well. The robot also has 8” of cross-wheel travel when the suspension is unlocked.
I hope this helps clarify some of the features on our robot. Please feel free to post any more questions (or compliments of course )
First Updates Now Show Host.
Watch and Listen to FUN on Youtube, iTunes, and www.firstupdatesnow.com
FRC Emcee 2009-2016: Team 2826 Wave Robotics Lead Mentor 2001-2004 Team 93 NEW Apple Corps Alumni
CD Moderator
Unread 02-02-2010, 11:09 PM
I love it.
I think this year there will be two classes of competitive robots: Robots that can repeatedly and reliably go over the bump with insane flexibility, and variations on your standard 6 wheel drive (with 8 wheels, or big wheels) that trade a little less bump security for added traction on the ground. A winning alliance will need to have both of these to be as successful as possible, IMO.
I know I've already given my props (or "sucked up" depending on how you wish to put it), but I still think stuff like this is SUPER COOL.
Unread 02-06-2010, 02:06 PM
rath358's Avatar
rath358 rath358 is offline
AKA: max
FRC #0093 (NEW Apple Corps)
rath358 is on a distinguished road
Wow. That looks amazing. Something tells me that you guys are going to clean up again.
Unread 02-02-2010, 04:24 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
It would seesaw if there weren't another point holding it up somewhere else. The robot has more than four wheels.
Unread 02-02-2010, 04:35 PM
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
Taking some personal time
EricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond repute
They will have springs to keep it from seesawing when on flat ground
2002-2005 Appleton East High School: Team 93
2005-2011 Michigan Technological University: Team 857
2012-2016 Wave Robotics Team 2826
pic: Wave Robotics 2826 Kicker Prototype Tyler Olds Extra Discussion 8 01-25-2010 03:44 PM
pic: Wave Robotics with Dean Kamen, their newest member, at EAA Meet & Greet CarterM Extra Discussion 8 08-07-2009 05:44 PM
pic: 599 Drive Teaser David Sherman Extra Discussion 13 01-24-2007 04:07 PM
pic: 213 - Drive prototype teaser Tyler M. Robot Showcase 10 01-07-2007 08:56 PM
pic: Toltechs drive-train teaser Andrew Schuetze Robot Showcase 21 02-06-2006 01:27 PM
